September 16, 2026, 11:32:00 am
Hoffman Amps Forum image Author Topic: AB165 Bassman Output transformer identification help  (Read 12927 times)
« on: January 28, 2021, 02:53:10 pm »
Got an AB165 on the bench. Funny though this one has an OT with two output impedances.  Has Black -Green- Green/Yellow wires.
Part number is 021009 and it was made in 1964.
I've looked around the net and can't find anything on this one.
Anyone have any info on it?  It's a brute.
Re: AB165 Bassman Output transformer identification help
« Reply #1 on: January 28, 2021, 03:56:07 pm »
I would say its a 60W OT with 4k2 Pr and 4R and 8R secondaries. Yellow and Green are the 60s Fender OT wire colours for 4 and 8 respectively, and if it looks bigger than 40W, its probably 60W. Classic Tone has a possible replacement candidate http://www.classictone.net/40-18008.pdf If it measures the same size as that, its what it could be. YMMV
« Reply #2 on: January 28, 2021, 05:17:03 pm »
Thanks Tubeswell - I did see that CT OT 50/60W and was thinking this one is similar but this one is 3.75" x 3.75" x 3.5"H.   The one output wire is green with a yellow stripe.
I guess it might be an original transformer just not sure.
« Reply #3 on: January 28, 2021, 05:40:13 pm »
Might be 100W OT then - Is there a Fender date code on it?
« Reply #4 on: January 28, 2021, 05:50:42 pm »
yes  066 412
« Reply #5 on: January 28, 2021, 05:52:40 pm »
I was thinking it might be a 100w OT  as it almost doesn't fit in the alloted space on this 65 bassman.  So I'm wondering if the input is for 4x 6L6 or 2x 6L6 ?
« Reply #6 on: January 28, 2021, 05:56:20 pm »
Depends what speakers that whoever did the conversion were running with it. The aim for 2 x 6L6GC is 4k (or 4k2) plate-to-plate.
You could put 5 or 6VAC on each of the secondaries and see what you got on the primary (disconnect the CT from the reservoir cap first)
« Reply #7 on: January 28, 2021, 06:03:24 pm »
Right I was just thinking Im going to have to check this one out electrically ..     I'll get to it tomorrow.   Thanks for the assistance.
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #8 on: January 28, 2021, 06:16:41 pm »
It's a Twin Reverb II OT.
4-6L6
105W
GRN/YEL  4 ohms
GRN  8 ohms
Manufactured in the 12th week of 1984
« Last Edit: January 28, 2021, 06:32:05 pm by 2deaf »
« Reply #9 on: January 28, 2021, 08:21:47 pm »
Thank you 2 Deaf..   so we will be getting a new Mercury OT for this amp.  I see that now in the Schematics index.    cool..   again  thanks .
« Last Edit: January 28, 2021, 08:27:36 pm by mresistor »
Offline J Fletcher
« Reply #10 on: January 29, 2021, 12:51:08 pm »
 That's a pretty good transformer , though in a Bassman the best speaker load would now be 8 ohms or 16 ohms , depending on which tap is used. Lots of people are running these amps in 8 ohm enclsures . Just sayin' FWIW .
« Reply #11 on: January 29, 2021, 05:30:59 pm »
Thanks J   - actually I found a Classic Tone 40-18001 OT for sale..    they are good as I have one in my Super Reverb..   so   we are going with that option and a three way switch in the ext speaker hole.
My SR is a Hoffman boarded head.
« Reply #12 on: January 30, 2021, 03:29:14 pm »
It's worth knowing Fender used "125___" part numbers (like "125A13A") until sometime near early-mid 1966.  Then they switched to the 6-digit "022____" part numbers.  021___ and part numbers with a letter prefix came in later, sometime in the 70s.
« Reply #13 on: January 31, 2021, 10:37:36 am »
Thank you for that info HPB .
