August 30, 2026, 08:02:36 pm
Hoffman Amps Forum image Author Topic: How much clearance does a PT need?  (Read 5455 times)
Offline PharmRock
« on: February 09, 2021, 07:51:52 pm »
As mentioned in other posts, I am building a hybrid 50w plexi/jcm800.  The new build will be housed in a head cab that I had for an 18w TMB , which is a little shorter than your typical head cab.  The PT I am using for this amp is a standup transformer, and when test mounted on the chassis I end up having about 3/4" from the top of the transformer to bottom of the top board of the head cab.  The cab has a top and rear vent.
Is there anything I need to worry about with the limited clearance between the PT and head cab? I know that PTs can get a little warm, but I'm figuring that with the vents I should be ok.
Thanks for the advice!
Offline Latole
Re: How much clearance does a PT need?
« Reply #1 on: February 10, 2021, 03:20:14 am »
3/4 inches clearance; it is not very much and with heat from Power Tubes.....
With a top and rear vents, Yes it is ok. IMO.
Picture of the top vents will help ; how much square inches ?
« Reply #2 on: February 10, 2021, 06:25:56 am »
I use stand up PT's in my amps also.  And add vents above the power tubes.
With respect, 10thtx
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #3 on: February 10, 2021, 05:10:39 pm »
That is a great question. First pic is my nice and tight vintage car radio with PT and 6v6 glass PushPull 10w.
I'm repurposing to a 5c3 style guitar amp (second pic). Hope heat doesn't come back to burn me :-)
« Last Edit: February 10, 2021, 05:16:25 pm by scstill »
Offline jordan86
« Reply #4 on: February 10, 2021, 05:38:07 pm »
As other have stated, Id be more concerned about Power tube heat. Less so about power transformer. I’ve never had one get THAT hot. I’d prioritize venting to the tubes if it were me. In the end, will probably cause more pain to your head cab more than your tubes and tranny.
Offline PharmRock
« Reply #5 on: February 11, 2021, 08:01:59 am »
Both vents are pretty decent sized.  The top vent is 16.5x1.25 (~20 in2) and the rear vent is 14x2.25 (~30 in2).  Pics attached.
The interior volume of the cab is about 1600 cubic inches, with my 17x8x2.5 chassis taking up about 340 of that.
That looks like a much tighter fit than what I'm fretting over!  Hope you have some good ventilation for it.
That's a great looking cabinet tubenit.  I really like the circular ventilation holes.  Looks "organic".
Offline Bieworm
  • I like it loud!
« Reply #6 on: February 19, 2021, 10:34:09 am »
Wow!!! That's almost a very exclusive piece of furniture.  Perfect for storing expensive bottles
« Reply #7 on: February 20, 2021, 11:59:21 pm »
Tubenit does some outstanding & very beautiful woodworking!  Don't forget to check out his guitars.   :wink:
