September 15, 2026, 05:49:18 pm
Hoffman Amps Forum image Author Topic: Stumped - Marshall JMP 2203; Tube not conducting current  (Read 4901 times)
Offline BlackCrowe604
« on: February 15, 2021, 09:27:29 pm »
Hi All,
My JMP is making me scratch my head. Hoping someone may be able to provide some direction on this one. It has an additional preamp tube added, and a master volume. (4x) Preamp tubes & (4x) EL34s (V4 - V7).
I was running 4 bias probes, and V7 had 0Ma current. I proceeded to check voltages at tube sockets.
Initial Voltage Check @ Tube Sockets:
      1.   2.    3.     4.      5.     6.     7.   8.
V7. 0.   H.   499.  0.      -41.  NC.   H.   0
V6. 0.   H.   500.  500.  -41.  NC.   H.   0
V5. 0.   H.   500.  500.  -41.  NC.   H.   0
V4. 0.   H.   499.  500.  -41.  NC.   H.   0
So, from initial check, screen grid stuck out. Checked socket, it was missing, I replaced with 1Kohm.
After replacing 1Kohm screen grid, and measuring 1Kohm between pin 4&6, re-checked voltages, results below:
V7. 0.   H.   493.  493   -41.  NC.   H.   0
V6. 0.   H.   494.  493.  -41.  NC.   H.   0
V5. 0.   H.   494.  493.  -40.  NC.   H.   0
V4. 0.   H.   494.  493.  -41.  NC.   H.   0
Pin 4 now has voltage. Awesome! However.....
I replaced tubes, let them run for a bit, then noticed through bias probes that yet again, V7 is not conducting current. 0mA.
I rechecked new resistor and measures 1K ohm.
Is there something I am missing here, or perhaps not considering? What else should I check?
Any help would be much appreciated.
I hope all is well despite the crazy times we are living in lately.
Cheers!
« Last Edit: February 15, 2021, 10:36:27 pm by BlackCrowe604 »
Re: Stumped - Marshall JMP 2203; Tube not conducting current
« Reply #1 on: February 15, 2021, 09:52:56 pm »
Screen resistor should be 1K, not 100K.
« Reply #2 on: February 15, 2021, 10:35:49 pm »
Good catch, corrected.
Sorry, typo in post. Screen grids are all 1K. Replacement screen grid is also 1K.
« Reply #3 on: February 15, 2021, 10:53:42 pm »
Try a different bias probe with V7.
Do you measure zero ohms between V7 pins 1/8 and ground?
« Reply #4 on: February 15, 2021, 11:24:30 pm »
V7 Pin #1 to ground = 0.22ohms
V7 Pin #8 to ground = 0.22ohms
new bias probe showing 19mA thru the tube!! thanks!!
will try the rest of the probes individually to confirm if one of the probes is causing errors.
