September 18, 2026, 08:43:41 am
Hoffman Amps Forum image Author Topic: Sluckey's Amp Cradle  (Read 8297 times)
Offline mk_716
« on: March 20, 2021, 10:48:05 pm »
My take on Sluckey's amp cradle.
Thanks for the design, and the quick answers and help all 'round.
m.
Offline Latole
Re: Sluckey's Amp Cradle
« Reply #1 on: March 21, 2021, 04:07:11 am »
Very well made.
« Reply #2 on: March 21, 2021, 09:31:02 am »
Looks good! I put 2 EMT couplers on my pipes to make it easy to extend for wider chassis. Haven't needed them so far.
Offline mk_716
« Reply #3 on: March 21, 2021, 10:00:30 am »
oh, good idea.
I've got two builds going at the moment, a Sluckey revibe  :occasion14: and a PR.   The PR is a custom steel chassis done at a local CNC shop for a deluxe 20 years ago or so.   It's a beast compared to the Hammond aluminum I've got the revibe in.  I've switched back between them a couple times and it's just fantastic.   The PTs make these so unstable on a bench, the cradle removes that entirely.
Might use a couple of those as stops on one side or the other.
I drilled through both ends for the emt and put the feet on to accommodate a vertical desk I use for building.  Got the threaded knobs on amazon, use m6 for everything.
mike
« Reply #4 on: March 21, 2021, 10:06:36 am »
Now that's a good idea! If you need to cradle a wider just easily remove the two pipes and replace with longer pipes. Less fuss than fooling with the couplers. I may just modify mine if I ever work on a wider chassis.
« Reply #5 on: March 25, 2021, 10:50:41 pm »
Can you show us a pic of this?
I'm not understanding this.  :dontknow:
Offline mk_716
« Reply #6 on: March 25, 2021, 11:11:38 pm »
Hey Willabe,
   On Sluckey's original design (see here - http://sluckeyamps.com/cradle/cradle.htm, he drills through the right side, but just drilled the left to set the emt in place.  I used a kreg jig to attach the feet (pocket hole jig).
   I drilled through both uprights for the emt.   you can see on the emt goes through both uprights in this pic, I put some m6 threaded inserts in the front and back to fix it in place.
mike
« Reply #7 on: March 26, 2021, 09:58:07 am »
I added several mods to my cradle shortly after building it but forgot to update the web page. Well, I finally got a round tuit! Update here...
Offline mk_716
« Reply #8 on: March 26, 2021, 10:00:27 am »
Oh I'm doing both mods.
That solder spool thing is genius! :worthy1:
Offline dbishopbliss
    • Bliss Amplifiers
« Reply #9 on: March 26, 2021, 03:05:20 pm »
Since we are showing off our cradles... I originally built mine following Sluckey's design. For some reason the inserts and thumbscrews were not very stable and would not hold the EMT tightly. The cradle would rock (have you seen junior's grades?) back and forth. I had some left-over all-thread from an old TV stand I made that was 24 inches long. I repurposed them and used the hex nuts, washers and gaskets to hold the ends. Now, my cradle is super stable.
« Last Edit: March 26, 2021, 03:09:27 pm by dbishopbliss »
Check out my blog for more details. Bliss Amplifiers
Offline Latole
« Reply #10 on: March 26, 2021, 03:29:15 pm »
Very well made, congrat
Offline Latole
« Reply #11 on: March 27, 2021, 03:16:42 am »
My amp cradle.
Very easy( and cheap)  to built and fast to set to any chassis size.
