September 16, 2026, 05:22:39 am
Hoffman Amps Forum image Author Topic: Two small voltage caps in series  (Read 5727 times)
Offline dude
« on: April 19, 2021, 02:53:43 pm »
Putting two small caps, say two 50uf's @ 25V in series, do I need balancing R's?  If so, what valve should the two R's be using 25v caps.
Offline acheld
Re: Two small voltage caps in series
« Reply #1 on: April 19, 2021, 05:13:07 pm »
https://www.illinoiscapacitor.com/pdf/Papers/voltage_balancing_resistors.pdf
Honestly, I usually wing it.  But this is the book answer.
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #2 on: April 20, 2021, 04:27:12 pm »
How many volts total across the series combination?
« Reply #3 on: April 20, 2021, 05:32:03 pm »
You’ll get 25uF and (if you use equal balancing resistors) 50V capability.
But if you need less than (say) 20V all up, then you can do without balancing resistors.
Offline dude
« Reply #4 on: April 20, 2021, 07:52:48 pm »
Just don’t have any 25uf’s in stock for cathode on 12ax7, (1st or 2nd stage), wanted to try the 25uf vs the 4.7 l have now. Voltage is probably less then 3v.
Tubeswell, so at that low voltage you say forget the balancing R’s.
It’s just temporary, if l like the tone l’ll get the correct value.
Offline thetragichero
« Reply #5 on: April 20, 2021, 11:43:19 pm »
if it's just for cathode bypass why not just try a 50uf there and keep it simple? for a 100k/1k5 typical fender stage the difference between 25uf and 50uf is imperceptible (0.03db at 82hz)
Offline dude
« Reply #6 on: April 21, 2021, 09:25:23 pm »
I don’t think so, l definitely can hear the difference between 4.7 and 25uf
« Reply #7 on: April 21, 2021, 09:53:25 pm »
Yes, but with larger value caps, I think it's because once you get to 25uF there's very little to gain, with guitar, by going larger.
