September 19, 2026, 07:10:00 pm
Hoffman Amps Forum image Author Topic: Diode rectifier  (Read 4666 times)
Offline Stuff4bikes
Diode rectifier
« on: June 21, 2021, 07:02:44 pm »
Can someone show me a schematic with the appropriate diode configuration for a NON center tapped transformer in a guitar tube amplifier?
I am confused on the (-) side of the rectifier with a safety ground.
Re: Diode rectifier
« Reply #1 on: June 21, 2021, 07:19:52 pm »
It's called a Full Wave Bridge Rectifier. Here's a real world example...
     http://sluckeyamps.com/revibe/revibe.pdf
And here's how it works...
Offline Stuff4bikes
Re: Diode rectifier
« Reply #2 on: June 21, 2021, 07:26:45 pm »
 Thank you. I understand how it works, I never see the bridge ground and the mains ground together.
So I can ground the mains and rectifier both to the chassis?
Re: Diode rectifier
« Reply #3 on: June 21, 2021, 07:34:58 pm »
Yes, both will connect to chassis, but not at the same place. Use a separate dedicated bolt for the mains ground. And ideally, the bridge ground should connect directly to the reservoir cap negative lead.
Offline Stuff4bikes
Re: Diode rectifier
« Reply #4 on: June 21, 2021, 07:48:30 pm »
Thank you sluckey......all I needed to hear....
