September 21, 2026, 04:52:34 pm
Hoffman Amps Forum image Author Topic: New 18 Watt TMB Build (Mojotone Kit)  (Read 8233 times)
Offline 72Blazer
  • Long live rock!
« on: June 25, 2021, 03:05:08 pm »
I just completed this build with all new components.  Sounds really good and really quiet with the exception of two very scratchy pots on the master volume channel (Gain and Treble Pots).  I' cleaned both pots to no avail.  Amp tech stated "It is very unusual to have 2 bad CTS pots.  Because these are on the same channel I bet you have a leaky cap somewhere allowing DC to pass.  This would explain why you can't get rid of the scratchiness with cleaner."
Anybody ever run into this type of issue?
Offline 72Blazer
  • Long live rock!
Re: New 18 Watt TMB Build (Mojotone Kit)
« Reply #1 on: June 25, 2021, 03:05:49 pm »
Pic 1
Offline 72Blazer
  • Long live rock!
« Reply #2 on: June 25, 2021, 03:06:19 pm »
Pic 2
Offline 72Blazer
  • Long live rock!
« Reply #3 on: June 25, 2021, 03:06:47 pm »
Pic 3
« Reply #4 on: June 25, 2021, 03:20:36 pm »
Yes, we all have. Very common. Most likely the 500pf treble cap. If not that one then one of the .022s.
Offline 72Blazer
  • Long live rock!
« Reply #5 on: June 25, 2021, 04:01:54 pm »
It was the 500pf treble cap!
Offline 72Blazer
  • Long live rock!
« Reply #6 on: June 25, 2021, 04:47:03 pm »
Well it sounded great for about 5 minutes now I got an electrical storm in the MV channel which I did not have before. I've only got one more 500pf cap left in my supply.  I'll try that one and if that don't work I'll start changing out those .022s
Offline 72Blazer
  • Long live rock!
« Reply #7 on: June 25, 2021, 07:20:50 pm »
I guess the third time (cap) is a charm...
« Reply #8 on: June 25, 2021, 09:13:55 pm »
You have to be very careful with those silver mica caps, too much heat soldering them and their toast.
Offline 72Blazer
  • Long live rock!
« Reply #9 on: June 27, 2021, 12:27:43 pm »
Thanks for the tip-I'll use a heat shrink from now on.  Amp still working great but I sure miss fender spring reverb
Has anyone taken a similar amp and and added reverb?
« Reply #10 on: June 27, 2021, 12:44:08 pm »
That's a good question for 18watt.com.
Offline dude
« Reply #11 on: June 27, 2021, 05:15:15 pm »
Yes, several guys at 18 watt added reverb but that was several years ago. Maybe go over there and check it out
Offline Bieworm
  • I like it loud!
« Reply #12 on: June 28, 2021, 03:06:45 am »
JMPGuitars designed an amp called " tremolo TMB reverb ". I have built 4 of them already and IMHO it's the best amp I ever heard. I know that's subjective, but nevertheless you're welcome to check it out on 18watt.com. you're very welcome!!!
Not trying  to steal you from EL34world or anything. Great guys here en great Help too...
Offline JB
« Reply #13 on: June 28, 2021, 04:03:43 am »
Marshall did make a version of the 18W amp with reverb, the "Master Reverb".  Very rare beast, I had a chance to play one and look inside.  They used a single ECC83 with the send half tapped off the first stage anode and the recovery stage feeding into the second half of the LTPI.  3 x ECC83 in total, single channel with tremolo.
