June 16, 2026, 04:40:23 am
Hoffman Amps Forum image Author Topic: Looking for PT candidate for JMP-1watt Clone  (Read 4999 times)
Offline Rp3703
  • Inexperienced Expert
« on: July 17, 2021, 12:51:57 pm »
I am looking at building a JMP-1 watt clone. I found this schematic and have for the most part confirmed it’s accuracy. I plan on using a Hammond 125A for the OT but am having trouble figuring out the PT. The Dragnall puts out 0-200V/ 0-11.5V on the secondary. Does anyone know of a hammond or other manufacturer with something similar or an alternative power amp solution that uses a commonly available PT? Is there an advantage to running the filament supply DC?
Re: Looking for PT candidate for JMP-1watt Clone
« Reply #1 on: July 17, 2021, 01:40:35 pm »
DC heaters can actually at times be nosier.
I like to use dcv elevated heaters with a humdinger pot. (I use 70 to 80dcv.)
Read this;
http://www.valvewizard.co.uk/heater.html
« Last Edit: July 17, 2021, 01:49:16 pm by Willabe »
Offline Rp3703
« Reply #2 on: July 17, 2021, 03:37:33 pm »
Are DC filaments just a PCB thing?
« Reply #3 on: July 17, 2021, 04:00:21 pm »
no
Offline Rp3703
« Reply #4 on: July 17, 2021, 04:15:11 pm »
But other than reducing hum, they do not contribute to the tone of an amp, right? So going with regular AC heaters would be fine if implemented correctly.
Offline thetragichero
« Reply #5 on: July 17, 2021, 04:36:40 pm »
i built a ~4w single-ended el84 plexi clone using the hammond 269ex transformer (probably most known for the ax84 high octane) i had lying around and it worked well for me
« Reply #6 on: July 17, 2021, 06:16:42 pm »
They do not change the tone of the amp. Very few guitar amps have dc heaters, and their quiet.
Offline Rp3703
« Reply #7 on: July 17, 2021, 07:38:20 pm »
Thanks Willabe, I think I’ll try AC filaments and see what happens.
Tragichero, I actually have a spare 269EX from a Firefly I built, I’ll give that a try and see how that goes as well. Thanks.
