September 16, 2026, 10:23:00 am
Hoffman Amps Forum image Author Topic: Any suggestions for an electrical safety floor mat  (Read 9062 times)
« on: August 03, 2021, 09:13:26 am »
I have my current workbench setup in my basement which is a concrete floor.
I'm open to any suggestions for an electrical insulation layer between my feet and ground.
I've heard of these and seen a few but just wondering if there is anything out there that you guys are aware of that will protect me and not break the bank.
I'd like it to be rigid enough that I can sit on my stool on top of it.
Something like this: (I only need it to be about 4' x 3' ish)
NOTRAX Switchboard Runner, Corrugated Surface Pattern, 12 ft L, 3 ft W, 1/4 in Thick - 5T434|830C0036-12 - Grainger
Offline acheld
Re: Any suggestions for an electrical safety floor mat
« Reply #1 on: August 03, 2021, 10:22:03 am »
I love the way the product description states:
Vinyl compound grounds workers to prevent electrical shock.
  But then in the technical specs:
Mat Electrical Resistance - Non-Conductive
Yeah, that is an expensive mat . . .
If it were me, I'd probably buy plastic square tiles as used in garage or automotive applications.  Should work just fine for this situation.  Though obviously not certified to ANSI/ASTM D178-01.
The truth is, it's really the "one hand" rule that is going to save you from high voltage AC going through your  heart.
« Reply #2 on: August 03, 2021, 10:50:21 am »
Just get this for electrical insulation...
https://www.amazon.com/gp/product/B0759BYPG3/ref=ox_sc_act_title_1?smid=A2WQUOY468PPWO&th=1
However, insulation is a bad idea if you ever work on static sensitive equipment. For that you need a mat that is conductive and has a wrist strap and a ground bonding strap. Like this...
https://www.amazon.com/Bertech-Wrist-Strap-Grounding-0-093/dp/B00HFQPS7M/ref=sr_1_22_sspa?dchild=1&keywords=antistatic%2Bmats&qid=1628005295&sr=8-22-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzUzY1VUw1QkMzSFIyJmVuY3J5cHRlZElkPUEwODgzMDk1MVE0RlRMREw5Qkg2JmVuY3J5cHRlZEFkSWQ9QTAzNjAyOTQyNDBOR1FBN1hQTjUwJndpZGdldE5hbWU9c3BfYnRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ&th=1
I have an ESD mat but I only take it out of the box when I'm working on computer stuff. Do you really want a mat? I hate 'em.
« Reply #3 on: August 03, 2021, 12:24:53 pm »
I don't like matts either, I like wood, probably NOT OSHA approved, but it works as long as there's not a big wet spilled beer puddle.
a good pair of muck boots works well when i'm playing  in the Mains panel  :icon_biggrin:
Offline dbishopbliss
    • Bliss Amplifiers
« Reply #4 on: August 03, 2021, 04:53:09 pm »
I don't know how insulated these are, but I had them on the floor of my work room at my old house. I just liked that they were cushioned. https://www.homedepot.com/p/TrafficMaster-Black-24-in-x-24-in-Foam-Interlocking-Gym-Flooring-24-sq-ft-6-Pack-24224DPHD/313099809
Check out my blog for more details. Bliss Amplifiers
« Reply #6 on: August 03, 2021, 08:07:53 pm »
Thanks for the responses guys.
Looks like PRR nailed it. I can get one of those 4'x3' rubber mats in stock from a Tractor Supply that I pass on the weekends.
heavy duty + perfect size + $30 + no shipping = WINNER
That mat is just perfect and I'm really glad I asked. Especially because I can do the rest of the floor in those foam puzzle pieces that are 1/2" thick (like dbishopbliss suggested) and have the height match up.
Thanks AGAIN PRR!
« Reply #7 on: August 03, 2021, 08:20:14 pm »
Hope your stool isn't on wheels.
« Reply #8 on: August 03, 2021, 08:55:06 pm »
Well, not yet, but I'll let you know how I make out. The surface doesn't look too too bad. I'll stop back and give an update once I get rolling (or not)
I can always get reimbursed and take this into work and use it as an anti-fatigue/insulation mat if it doesn't work out.
I usually stand at my bench there and it's concrete as well.
« Reply #9 on: August 03, 2021, 10:39:01 pm »
Put a piece of plywood on top of the rubber mat if you want to use a stool.
« Reply #10 on: August 03, 2021, 11:45:29 pm »
I too was assuming standing. Stool-feet/wheels will need the hard mat in reply #2.
« Reply #11 on: August 04, 2021, 06:51:12 am »
:laugh:
i STOP there 3 days a week, but I do pass by a Starbuck's to get there  :icon_biggrin:
« Reply #12 on: August 04, 2021, 07:40:43 am »
Now, now...that's somethin shooter would do  :icon_biggrin:
« Reply #13 on: August 04, 2021, 07:42:54 am »
:laugh:
You should stop in to S-Bucks just to use the bathroom.
They're not allowed to stop you.
Starbucks’ Open Bathroom Policy Comes With Heavy Cost, Study Finds (forbes.com)
« Reply #14 on: August 04, 2021, 08:29:37 am »
It's about 50 stand/50 sit now.
I was actually considering one of these since I don't really sit there for comfort. It's more about functionality.
Uncaged Ergonomics Wobble Stool 33" Active Sitting Standing Desk and Office Stool (WSb) | Staples
« Reply #15 on: August 04, 2021, 09:21:21 am »
  • ROUNDED BASE is stable & lets the stool move with you to burn calories. Special design allows you to sit normally without constant movement
Heck, if I can burn calories while I work maybe i'll never hit the weight limit   :icon_biggrin:
  • 250 lb Weight Capcacity
« Reply #16 on: August 04, 2021, 09:29:27 am »
:laugh:
naw, I just piss on the dumpster out back, inside is to WOKE for me  :icon_biggrin:
