September 14, 2026, 03:26:29 pm
Hoffman Amps Forum image Author Topic: Hoffman 6v6 plexi bias help  (Read 7593 times)
Offline Mehfuzhoss
« on: August 16, 2021, 11:22:52 pm »
Hello Sir,
I put new 6v6GT in the amp. The bias current is 50ma per tube and the bias pot is at minimum position.
What should I do?
Offline BlackCrowe604
Re: Hoffman 6v6 plexi bias help
« Reply #1 on: August 17, 2021, 01:01:18 am »
turn the pot clockwise to add resistance in order to drop the bias current.
let us know the minimum current value (mA) that you can achieve with your current circuit configuration.
50ma is too high for 6V6s.
what is your plate voltage?
Offline Latole
« Reply #2 on: August 17, 2021, 03:15:09 am »
Bias milliamps reding is only usefull if you know plate voltage.
With 50 ma your plate voltage must not be over 200 volts, I guess is much over that, close to 400 ?
And close to 400 volts bias must be 20ma
At 50 ma at 200 volts it is 70 % power dissipation. I like bias close to 60% not 70%
Your power tubes may have a short inside to have so much current. Try know good tube.
https://www.tedweber.com/bias-calc/
« Reply #3 on: August 17, 2021, 07:07:46 am »
Hello Sir,
What should I do?
What happened when you read the install instructions for that board?
https://el34world.com/schematics.htm#Hoffman_Plexi_6V6
« Reply #4 on: August 17, 2021, 07:33:05 am »
Hello Sir,
What should I do?
Is this the first time you turn the amp on?
Offline Mehfuzhoss
« Reply #5 on: August 17, 2021, 08:22:15 am »
Plate voltage 400
« Reply #6 on: August 17, 2021, 08:41:45 am »
Is this the same amp you asked about in May?
     https://el34world.com/Forum/index.php?topic=27537.msg302492#msg302492
Offline Mehfuzhoss
« Reply #7 on: August 17, 2021, 12:34:07 pm »
yes sluckey. I liked the amp a lot and had a duet mesa boogie 6v6 in it and i was able to set the bias current to 27mv. I recently built a dlite 22 and took out the power tubes to test it. now the mesa 6v6 duets are in the d'lite.
i bought brand new Groove Tube 6v6GT from local music store and put it in. the bias reading was showing 250mv and I turned the bias pot all way to minimum and currently the reading is 50mv. I left the amp aside for now.
I read that these 6v6GT can handle upto 70mv maximum, but I would like to keep it under 30mv.
please advise.
« Reply #8 on: August 17, 2021, 12:37:58 pm »
please advise.
I posted the link to the install instructions
Did you read the section on how to bias the amp?
All the info is there on how to adjust or modify the bias section
Did you read the instructions?
https://el34world.com/Hoffman/instructions.htm
Offline Latole
« Reply #9 on: August 17, 2021, 01:12:17 pm »
please advise.
Wrong, you don't understand what are bias.
6V6 GT can handle 12 watts, that is only you need to know first
Reading plate voltage are a must . Let say for 300 volts plate voltage and for a tube dissipation at 60% ( don't  go over 70% in Class AB amp )
If you read 70 mv ( ma )
Power = 70 mv (ma ) X 300 volts =21 watts !!!!!! for a 12 watts tube  :BangHead:
You will blow you tube
12 watts  X 70% = 8,4 watts. at 300 volts you must read close to 27 mv ( ma
 At 400 volts Plate voltage, don't go over 21 mv (ma)
« Last Edit: August 17, 2021, 01:16:03 pm by Latole »
« Reply #10 on: August 17, 2021, 01:14:04 pm »
please advise.
Put the mesa 6v6s back in the plexi amp and re-bias. Return the Groove Tube 6V6s to the local music store. Buy another set of 6V6s for your d'lite from an online electronics store.
« Reply #11 on: August 17, 2021, 02:36:07 pm »
Plate voltage 400
(14/400) * .7 = 25mA. set bias around 22-25mA and you should be good to go.
PD for 6V6 = 14w.
Offline Latole
« Reply #12 on: August 17, 2021, 02:38:57 pm »
After setting bias first time ,check plate voltage it may change and re adjust bias with this new plate voltage.
