August 29, 2026, 08:27:55 pm
Hoffman Amps Forum image Author Topic: Modern KT77 remakes  (Read 5994 times)
Modern KT77 remakes
« on: September 20, 2021, 09:46:35 am »
Anybody here ever use any of the modern remakes of the KT77 power tubes?
How do they sound compared to EL34's? Do you like them?
Offline thetragichero
Re: Modern KT77 remakes
« Reply #1 on: September 20, 2021, 10:14:26 am »
i used the jj kt77 in a build and they sounded fine. i originally needed something capable of higher anode voltage but i scrapped that idea
« Reply #2 on: September 20, 2021, 11:03:40 am »
A Marshally sounding build? If so, do they sound like EL34's?
Guitar amp, bass amp? Hi-gain, crunch, mids hump voiced amp?
« Reply #3 on: September 20, 2021, 11:10:09 am »
« Reply #4 on: September 20, 2021, 02:54:37 pm »
it was a clone (mostly) of one of marshall's oddest amps: the 100w jcm800 bass amp. i built it in a gutted dsl 100 chassis so the fourth preamp tube hole ended up with a second, more guitar-voiced input (i labeled it 'bright') and the two channels could be jumped like any good 4-hole marshall. this amp uses an incredible amount of global negative feedback to keep relatively clean so couldn't really comment on standard marshall "bark"
Offline 66Strat
« Reply #5 on: September 20, 2021, 04:02:09 pm »
I came across this video at TGP of currently available EL34 tubes compared to vintage EL34s. Seems like a pretty thorough comparison. No KT77s, but there is a 6CA7 tube included.
https://www.youtube.com/watch?v=4WdaFeGr07k&t=3s
Regards,
JT
Offline _Steve
  • Tinkerer
« Reply #6 on: September 21, 2021, 03:07:23 pm »
I use new production Gold Lion KT77s in a bass-spec plexi clone. Same powerful mids as EL34s but with better lows and highs. There's no downsides I can tell, except the price.
Offline SoundmasterG
« Reply #7 on: September 23, 2021, 09:32:26 pm »
I used JJ KT77's in a Vox AC100 clone build. They sounded and worked great. I'll definitely use again when these ones die.
As far as comparing them to EL34's, I'd say maybe a little cleaner and clearer with more lows and highs, but it is subtle. They are definitely closer to an EL34 sound than a 6L6 sound.
Greg
