August 29, 2026, 08:26:53 pm
Hoffman Amps Forum image Author Topic: Heaters to high  (Read 5705 times)
Offline Tone Junkie
Heaters to high
« on: September 21, 2021, 12:57:27 am »
So my heaters on my tubes are at 6.8 . I’m not good with the math any idea what ohm to stick in there to lower. And what wattage z if math example is put in the answer I can put this on my wall of knowledge for later use. I’m forgetful so I post it in my computer room wall. So I can quickly get the answer next time . Lol Bill
Re: Heaters to high
« Reply #1 on: September 21, 2021, 01:22:30 am »
Tubes can run their heaters +/- 10%. So your still good.
6.3 x .1 = .63
6.3 + .63 = 6.93
6.3 - .63 = 5.67
What's your wall acv? What amp? Is it old, schematic show 117acv wall voltage or lower? What PT? Does your PT have an over rated current heater supply for what tubes your running in the amp? Did you change power tubes that draw less heater current? Like going from EL34's to 6L6GB/GC's?
You could build a bucking transformer box. From Sluckey's web site, 2nd page, Buckaroo;
http://sluckeyamps.com/misc/Amp_Scrapbook.pdf
« Last Edit: September 21, 2021, 01:26:05 am by Willabe »
Offline Latole
Re: Heaters to high
« Reply #2 on: September 21, 2021, 03:15:07 am »
What amp?
What PT?
Right !
Re: Heaters to high
« Reply #3 on: September 21, 2021, 03:06:47 pm »
That question needs Current. Which means looking-up and adding-up the tubes in your unspecified amp.
Offline acheld
Re: Heaters to high
« Reply #4 on: September 21, 2021, 09:29:54 pm »
But, why?
Offline Tone Junkie
Re: Heaters to high
« Reply #5 on: September 21, 2021, 09:33:56 pm »
2x6l6 and 3 12ax7s  the transformer is new but could be 20 years old. New as in hasn’t been inside anything.
Offline Tone Junkie
Re: Heaters to high
« Reply #6 on: September 21, 2021, 09:35:07 pm »
Could be an over rated supply.
Re: Heaters to high
« Reply #7 on: September 21, 2021, 09:58:52 pm »
What PT?
Brad/name, model #?
Offline Tone Junkie
Re: Heaters to high
« Reply #8 on: September 21, 2021, 11:17:43 pm »
Ok I’m at work right now. Will put up when I get home. Thanks
Re: Heaters to high
« Reply #9 on: September 21, 2021, 11:51:30 pm »
You want to drop 6.8V-6.3V= 0.5V at 0.9A+0.9A+0.3A+0.3A+0.3A= 2.7A
0.5V/2.7A is 0.1852 Ohms.
0.5V*2.7A is 1.35 Watts. (Round up at least double.)
While maybe not essential, it is prettier if split to both sides. Two of 0.09Ω@2W
DigiKey:
53JR10E RES 0.1 OHM 5% 3W AXIAL $0.25     4,407 - Immediate
13FR080E-B RES 0.08 OHM 1% 3W AXIAL   $1.26   800 - Immediate
12FR090E RES 0.09 OHM 1% 2W AXIAL $1.83     14 - Immediate
The 25 cent parts will drop 2*(0.1Ω*2.7A)= 0.54 Volts, from 6.8V makes 6.26V, which is close enough for Maine contra-dancing.
Offline glass54
Re: Heaters to high
« Reply #10 on: September 22, 2021, 12:33:38 am »
I've done exactly the same. Marshall JCM2000 series was running heaters at 7.4V!! (Someone in the Transformer factory must have put in a couple extra turns in Heater winding for Good Luck  :laugh:)
I did a little trial and error (based on common sense and using Fluke multimeter), finding a suitable resistor, halved that and used 3W wirewounds in each Heater leg (because I had the correct values) and ended up with 6.38V. Amp was happy.
Regards
Mirek
"To measure is to know"
Offline Tone Junkie
Re: Heaters to high
« Reply #11 on: September 22, 2021, 10:49:23 pm »
Thanks you guys . Bill
