September 15, 2026, 11:08:08 am
Hoffman Amps Forum image Author Topic: PT stray voltage?  (Read 7033 times)
Offline BrassElephant
  • You have no idea how high I can fly
PT stray voltage?
« on: November 10, 2021, 09:14:14 pm »
Hello all, first thread here. Love this community, thanks to all.
I have a little PT on the bench, it comes out of an old tube CB radio. Schematic here: http://www.bunkerofdoom.com/lit/cb/sonarfs23/sonar_FS23_schematic.gif
The schematic is sorta hard to make out at first, but that's not really part of the issue.
Whenever I energize the primary, I get the expected voltage readings on each set of secondary windings.
I first did this test with the PT still installed in the chassis. All of the windings were disconnected and floating (gator-clipped and insulated and safe), but the PT was still physically installed in the chassis. No earth ground connection. I rested my hand on the chassis for a second, and felt a slight vibration. DMM said 52V between chassis and earth ground (outlet on bench).
So I took the PT out of the chassis, and tested again. Same result, 52V on screw-posts thru the PT.
Gator-clipped screw-posts to earth ground on bench. Voltage on screw-post disappears, no change in secondary voltage readings, no current draw.
So my gut tells me this is normal. Just wanted to be sure. What's the word?
Re: PT stray voltage?
« Reply #1 on: November 10, 2021, 10:28:18 pm »
It's called a phantom or ghost voltage. Put a 1K resistor across your meter leads and it should disappear.
« Reply #2 on: November 10, 2021, 11:14:45 pm »
If the transformer stray capacities are exactly balanced, you expect an ungrounded transformer to float to half the 120V supply. A little less counting meter-loading. 52V is not unreasonable.
You also see this when checking "3-way" switches on stair lighting. The traveler lead can be floating on both ends and on a hi-Z meter will read 50V or so, because it runs right with a 120V and a 0V wire.
1k loading will make it 'go away'. 10k and 100k are more typical *initial* skin resistances; but if you don't let-go a continued electric shock will break-down cell-walls leaking cell-juice and skin resistance quickly drops to 1k or less.
« Reply #3 on: November 10, 2021, 11:16:00 pm »
Ah, I see. That did the trick indeed.
Time to go read up on phantom voltage.
Thanks a ton!
« Reply #4 on: November 11, 2021, 08:19:15 am »
I recently bought a Klein MM770 dmm that actually has a Lo-Z mode especially for dealing with phantom voltages. Lo-Z mode actually puts a 3K resistor across the probes. Occasionally useful to bench techs. More useful to an electrician that deals with long runs of electrical cables.
« Reply #5 on: November 11, 2021, 08:32:55 am »
Oh interesting.
To be honest, I'm a 2nd year electrician apprentice. So I really should've known about this phenomenon already haha. I seem to remember an occurrence like PRR mentioned, on a service call, phantom voltage on the travelers in a 3-way switch. But this phantom voltage on a high voltage PT didn't ring that bell.
Now I know!
Offline thetragichero
« Reply #6 on: November 11, 2021, 08:47:34 am »
this solves a conundrum i had a few weeks back. thank you
« Reply #7 on: November 11, 2021, 12:42:24 pm »
Electricians are very practical people. And electric utilization is not as simple as it may seem. So even experienced electricians rarely get into the "why". Just say "stray voltage!" a lot.
Here the key lesson is: if you can touch it, ground it!
« Reply #8 on: November 11, 2021, 01:32:32 pm »
Now THAT is something I've always known, way before I ever started my adventure into electricity.
This was just the first time I had ever noticed potential on a xfmr housing. I've tested PTs out on the bench before and never noticed it. Is this something that doesn't occur with every PT? Or just something I didn't catch before?
If the chassis was earth-bonded, I wouldn't have noticed it this time. But since it wasn't, and because I saw it, I just wanted to be sure this PT wasn't malfunctioning in some way. When I gator-clipped to earth and didn't get any sparks or smoke, or glow on the dim-bulb, I assumed it was a common phenomena. Just wanted to check here with the experts.
« Reply #9 on: November 11, 2021, 02:26:46 pm »
When I did my apprenticeship, filament lamp test probes were the preferred kit to check for mains power, as they wouldn’t respond to such stray voltages. eg https://docs.rs-online.com/def9/0900766b80494f46.pdf
Offline Williamblake
« Reply #10 on: November 11, 2021, 02:46:28 pm »
So does the winding in old power transformers that is grounded on one side and floating on the other solve this?
« Last Edit: November 11, 2021, 04:36:47 pm by PRR »
« Reply #12 on: November 12, 2021, 10:05:05 am »
So I was bored last night and hooked up this test again. This time put the DMM between outlet hot and xfmr primary, looking for current.
It shows 192ma of current thru the primary, both with earth-bond and without. No load on the secondary. Is this expected?
Also, is this phantom voltage occurrence common to every PT, or just some?
Thanks for educating me
« Reply #13 on: November 12, 2021, 11:14:38 am »
....DMM between outlet hot and xfmr primary, looking for current. It shows 192ma of current thru the primary,
Exciting current.
Antek has no-load specs:
50VA  https://cdn2.bigcommerce.com/server6000/2b6qq/products/178/images/895/AS_0524__36611.1387480532.1280.1280.jpg
200VA: https://cdn2.bigcommerce.com/server6000/2b6qq/products/384/images/1346/AS-2234__64381.1510892638.1280.1280.jpg
These are toroids which may tend to lower exciting current than E-I types.
« Reply #14 on: November 12, 2021, 02:48:58 pm »
Exciting current. Thank you. Once I learn the common terms for the phenomena, I can finally type in the right stuff to do the proper research.
Thanks everyone!
