September 08, 2026, 10:28:34 am
Hoffman Amps Forum image Author Topic: Hoffman Fender eyelet board info  (Read 28289 times)
« on: November 20, 2021, 11:53:59 am »
The Fender parts List page is here with the layout diagram link
Go down to the bottom of this page
https://hoffmanamps.com/MyStore/catalog/PartsListIndex.htm
The Fender parts list have all the parts I stock and the Eyelet boards
Fender Eyelet boards catalog page is here
https://hoffmanamps.com/MyStore/catalog/EyeletBoard.htm
Some if the items I do not stock are listed here with Links
https://el34world.com/Forum/index.php?topic=23827.0
Items not included on the Fender parts list
Chassis
Faceplates
Cabinet
Transformers
The items above can be purchased at Mojo
https://www.mojotone.com
« Last Edit: July 18, 2023, 06:12:51 am by EL34 »
Re: Fender layouts
« Reply #1 on: July 18, 2023, 06:11:43 am »
Here's some info on Hoffman Fender layout boards.
My board material is not the same size as original Fender boards
The height is always 3.125 inches tall
Modern resistors have shorter leads and are only able to span maybe 2 inches from eyelet to eyelet
So the top and bottom rows on my boards have been shortened down to a 2 inch span
The way this is done is I take the original Fender layout as an image and then scale it down to get the 2 inch vertical span
This also shrinks the length.
My board sizes are listed on the Fender boards page here
Eyelet Boards
Every board has a link to the original Fender layout diagram
You still use the fender layout diagram to populate one of my boards
My boards do not use backing boards.
You use standoffs to raise the boards above the chassis surface.
You can see example of how my boards are mounted in this document that is used for my turret board installs
But much of it still applies to my fender eyelet boards
https://el34world.com/Hoffman/instructions.htm
Re: Fender layouts
« Reply #2 on: July 18, 2023, 06:11:56 am »
Some questions I get about my boards
Can you cut the height down from 3.125 inches to 2.5 inches?
No, sorry
I get all my board material cut into 3.125 inch x 48 inch long strips by my board material supplier
I requires using a table saw with a fine toothed carbide blade
I don't do any table saw ripping here.
What backing board do I use?
You don't. You use standoffs as is shown in this document
Are the layouts the same as the original Fender board?
Yes, I just take the original layout diagram and scale it down a bit so that the top and bottoms rows are 2 inches apart to accommodate modern resistor lengths
You use the original Fender layout diagram to install the parts on your board
What is the size of your Fender board?
The vertical height is always 3.125 inches tall
The lengths are all listed on the Fender Eyelet board page here
More questions and answers to come as I think of them
« Last Edit: July 18, 2023, 06:23:47 am by EL34 »
Re: Hoffman Fender eyelet board info
« Reply #3 on: July 18, 2023, 06:18:40 am »
future use
