August 29, 2026, 08:27:54 pm
Hoffman Amps Forum image Author Topic: KT66 to EL34  (Read 14798 times)
Offline Travis8
KT66 to EL34
« on: November 22, 2021, 06:24:56 am »
Hi, I have a tubeampdoctor JTM45 build with KT66.
How can I changue it to EL34? Thanks.
Re: KT66 to EL34
« Reply #1 on: November 22, 2021, 06:43:35 am »
Make sure Pin 1 of the output tube socket is connected to Pin 8.  Re-bias the amp when you install the EL34s.
You probably have some healthy screen resistors, but if not add 1kΩ 5w resistors going into Pin 4 of the output tube sockets.
Offline Travis8
Re: KT66 to EL34
« Reply #2 on: November 22, 2021, 06:49:05 am »
Here is the schematic
Offline Travis8
Re: KT66 to EL34
« Reply #3 on: November 22, 2021, 06:52:19 am »
Pin 1 go with pin 8, so I must swap 470ohm resistors with 1k resistor (between 4 and 6) and rebias when I install el34? No OT swap ?
« Last Edit: November 22, 2021, 07:28:41 am by RCZ »
Re: KT66 to EL34
« Reply #4 on: November 22, 2021, 09:08:48 am »
That's not a schematic. That's a layout drawing.
Re: KT66 to EL34
« Reply #5 on: November 22, 2021, 09:13:20 am »
Pin 1 go with pin 8, so I must swap 470ohm resistors with 1k resistor (between 4 and 6) and rebias when I install el34? No OT swap?
The layout drawing shows pin 1 is connected to pin 8, double check to make sure.
Yes, swap 1K/5w screen grid R's for the 470R.
Yes, re-bias when you swap the tubes.
No need to change the OT.
Re: KT66 to EL34
« Reply #6 on: November 22, 2021, 09:55:21 am »
… No OT swap ?
What are the electrical characteristics of the OT you’ve got, eg intended primary impedance?
If it's the typical JTM45 8k, then you may wish to try setting the impedance selector a step higher than the total effective load impedance.
That will take some stress off the screen grids.
« Last Edit: November 22, 2021, 12:22:58 pm by pdf64 »
Offline Travis8
Re: KT66 to EL34
« Reply #7 on: November 22, 2021, 03:46:36 pm »
… No OT swap ?
125c1a is my OT
Offline jordan86
Re: KT66 to EL34
« Reply #8 on: November 22, 2021, 03:49:24 pm »
That model # looks like a choke?!?
Offline Travis8
Re: KT66 to EL34
« Reply #10 on: November 22, 2021, 04:14:32 pm »
No, that's the choke.
That's not the OT.
Offline Travis8
Offline Travis8
Re: KT66 to EL34
« Reply #12 on: November 22, 2021, 05:20:48 pm »
… No OT swap ?
https://www.tubeampdoctor.com/en/output-transf.-for-marshall-jtm45-2xkt66-with-8-16-ohms?number=MJTM45A
Re: KT66 to EL34
« Reply #13 on: November 22, 2021, 05:31:09 pm »
Yes, that’s an 8k primary, so it’s worth trying the ‘alternative loading’ I suggested.
Offline Travis8
Re: KT66 to EL34
« Reply #14 on: November 23, 2021, 01:46:40 am »
So I must swap 1K/5w screen grid R's for the 470R.
Then I must use the impedance selector one step higher, for example, If I wanna use it with 8 ohms cab I must select 16 ohm output.
Finally I install EL34 and bias it
That´s correct?
Re: KT66 to EL34
« Reply #15 on: November 23, 2021, 03:41:57 am »
… I must use the impedance selector one step higher, for example, If I wanna use it with 8 ohms cab I must select 16 ohm output.
Finally I install EL34 and bias it ….
I don’t think the impedance thing should be considered mandatory. The change I suggested may be a bit easier on the EL34.
Consider trying it both ways.
Offline Travis8
Re: KT66 to EL34
« Reply #16 on: November 23, 2021, 03:46:27 am »
OK, I will try using EL34 with the step higher option. Thanks.
Offline Travis8
Re: KT66 to EL34
« Reply #17 on: November 23, 2021, 04:13:41 am »
If I replace resistors and I bias, I could still using the 4 ohms output?
Maybe I prefer to still having this option.
Re: KT66 to EL34
« Reply #18 on: November 23, 2021, 05:12:53 am »
Optimal load for an EL34 in centre bias Class A with a plate voltage around (say) 450 = 450/(25/450) = 8,100R which is 4,050R for a pair of EL34. Go slightly lower (say 3k2) to ensure the screens don’t overheat under big signal conditions.
You could run the pair at 8k but you’ll get less power output, and you’ll want good screen resistors to soak up excess screen current under big signal. (Higher load resistance = shallower load line = more Ig2 when plate voltage swings closer to zero).
Offline Travis8
Re: KT66 to EL34
« Reply #19 on: November 23, 2021, 06:11:08 am »
Maybe the safer way to do it is use 1k/5W and higher step on impedance selector. I always use 8 and 16 ohms cabs
Offline Travis8
Re: KT66 to EL34
« Reply #20 on: December 02, 2021, 10:13:47 am »
I change resistor and I rebias the amp, it´s work but sometimes loose power and I get some intermittent sound
Recommendation?
Re: KT66 to EL34
« Reply #21 on: December 02, 2021, 10:45:39 am »
So did it do that when the KT66 were fitted?
Has it ever worked right?
Offline Travis8
Re: KT66 to EL34
« Reply #22 on: December 02, 2021, 11:25:28 am »
No, with KT66 was fine
« Last Edit: December 02, 2021, 11:33:14 am by RCZ »
Re: KT66 to EL34
« Reply #23 on: December 02, 2021, 11:44:28 am »
What condition is the 1k 5W board mounted resistor (that feeds the screen grid resistors) in, eg looking overheated?
Offline Travis8
Re: KT66 to EL34
« Reply #24 on: December 05, 2021, 01:56:59 pm »
They look in good condition.
Maximum bias I can get it´s 30ma, I think is very low, how can I get more bias range?
Could low bias making the amps sound comes and goes?
thanks
Offline Williamblake
Re: KT66 to EL34
« Reply #25 on: December 06, 2021, 07:11:07 am »
Quote from: RCZ
thanks
Loosing screen voltage would do that. Dind't somebody just change the screen resitors?
Re: KT66 to EL34
« Reply #26 on: December 06, 2021, 07:49:56 am »
Maximum bias I can get it´s 30ma, I think is very low …
Why do you think that?
Bear in mind that the anode of KT66 isn’t as beefy as that of EL34.
Reduce the bias voltage (ie applied to pin5).
I can’t see how that could feasibly occur, especially as 30mA does not seem a particularly low idle current.
« Last Edit: December 06, 2021, 07:52:01 am by pdf64 »
Offline Travis8
Re: KT66 to EL34
« Reply #27 on: December 06, 2021, 07:57:58 am »
Quote from: RCZ
thanks
Yes, I use 1k 5W on screen resistor, but sound comes and goes :/
Re: KT66 to EL34
« Reply #28 on: December 06, 2021, 08:16:34 am »
sound coming and going is typically blocking distortion in the PI.  A scope comes in handy to know if that's the case.
Re: KT66 to EL34
« Reply #29 on: December 06, 2021, 09:02:40 am »
See attached pic to provide proper bias for EL34s...
Offline Travis8
Re: KT66 to EL34
« Reply #30 on: December 07, 2021, 06:12:46 am »
I will try 150k...
Blocking PI distorsion means?
Re: KT66 to EL34
« Reply #31 on: December 07, 2021, 08:14:06 am »
this explains it pretty well;
The Long-Tail Pair (aikenamps.com)
Re: KT66 to EL34
« Reply #32 on: December 07, 2021, 08:20:01 am »
There’s also http://aikenamps.com/index.php/what-is-blocking-distortion
If the issue can occur at non overdriven signal levels, then it won’t be blocking distortion.
Offline Travis8
Re: KT66 to EL34
« Reply #33 on: December 07, 2021, 08:48:34 am »
The amps sound but the sound comes and goes in all positions.
I will try to fix the bias issue and look if that helps...
Re: KT66 to EL34
« Reply #34 on: December 07, 2021, 10:39:48 am »
Missing or not-really-connected grid resistor. Any stage.
Offline Travis8
Re: KT66 to EL34
« Reply #35 on: December 10, 2021, 03:26:14 am »
I changue to 150k and now I can bias it better.
Bias now is 43ma and it´s look like the sound goes well :) thanks guys
