September 16, 2026, 10:02:57 pm
Hoffman Amps Forum image Author Topic: Adding VVR and Pentode preamp stage  (Read 6517 times)
Offline 1blueheron
« on: November 23, 2021, 09:17:16 pm »
This is a conceptual schematic.  I am sure I have made mistakes I am unaware of or unable to recognize.  I am attempting to apply VVR to the Output tubes only.  Objective is to get reasonable distortion at lower volume levels.  (VVR is at the suggestion of several respected forum members)
As is, the dishes are literally rattling in the kitchen, before there is any kind of discernible breakup.  Great clean, but nothing usable as far as distortion unless a pedal is used or you have a stadium to play in.
Hoping this additional gain stage will add some distortion and additional control of overall volume and some interesting tonal character.  The chassis has room for a small bottle near the input and I think this will fit nicely.  Have read a lot of posts about putting the pentode before vs. after a triode gain stage and am open to comments and suggestions.  Thanks.
Re: Adding VVR and Pentode preamp stage
« Reply #1 on: November 24, 2021, 12:55:10 am »
You need to sleep on that. Look again in the morning. It won't rattle the dishes because you are listing to clean DC point [D].
I never saw that way to tap signal (if there were any) from the screen feed.
The new pentode may like a grid resistor.
Did Webster really use 100k for 6L6 grid resistors?
Offline d95err
« Reply #2 on: November 24, 2021, 02:10:16 am »
This will not work.
First, the regulated voltage needs to be applied to bith the plate and screen voltages if the output tubes.
Second, if you are not scaling the premp and phase inverter voltages, you need some kind of post-PI master volume, to get the signal level into the output stage reduced as you turn the voltage down.
« Reply #3 on: November 24, 2021, 06:05:44 am »
Perhaps you may find some useful information with this schematic given a pentode in the preamp and VVR.
As an FYI, I quit using VVR's and now use a PPIMV.  I actually removed two VVR's from amps and replaced them with PPIMV.
« Last Edit: November 24, 2021, 06:36:36 am by tubenit »
Offline 1blueheron
« Reply #4 on: November 24, 2021, 06:51:56 am »
Attempting to fix mentioned issues.  Thanks.
Offline 1blueheron
« Reply #5 on: November 24, 2021, 07:19:07 am »
Here is an attempt to address some of the mentioned issues.
I borrowed heavily from Tubenits schematic on the 5879.  :icon_biggrin:  Will given values will work as well in second stage vs first stage?  It's a beginning point.
I have moved the gain pot to before second gain stage rather than before.
I have added node B to the varied portion of VVR
I believe the 100k screen grid resistors on the output tubes are stock and values correct but will visually confirm when I get back to the house.
I am thinking through the master volume PPIMV and what all is fed from the B node.  I think I would prefer the PI be fixed voltage and just the power tubes varied. still working through all the voltage drops.
« Reply #6 on: November 24, 2021, 08:02:11 am »
My understanding is the 5879 does not do well with a typical TMB tone stack?  My understanding is you need a cathode follower attached to the 5879 and then the TMB connected to the cathode follower.   I have had some success using a 5E3 type tone stack directly after a 5879.
« Reply #7 on: November 24, 2021, 08:58:05 am »
+ 1 for Tubenit
« Reply #8 on: November 24, 2021, 06:18:13 pm »
...  Objective is to get reasonable distortion at lower volume levels. ...
As is, the dishes are literally rattling in the kitchen, before there is any kind of discernible breakup.  Great clean, but nothing usable as far as distortion unless a pedal is used or you have a stadium to play in. ...
You would be well-served to think in terms of dB SPL and the sensitivity of the speaker you'll use.
I have a 2x12 cabinet that used to hold a S75-PVC (98dB) and M75-PVC (97dB).  The decibel chart said 80dB SL was the loudness of a vacuum cleaner, and getting 80dB from these speakers requires:
     Power = 10[(80dB - 98dB)/10] = ~15 milliwatts from the amp.
I can confirm that using a PRR 1/3 Watt amp into that cabinet, I got:
     dB SPL = 10 log (0.33w / 1w) + 98dB = 10 x -0.48 + 98dB = 93dB SPL
That is, it was loud enough for apartment neighbors to complain unless I turned down the one-third-watt even further.  Your takeaway should be that anything with the 6L6 output stage will be very much bigger than what you can drive to distortion at home.  Unless you're building a glorified overdrive pedal, that is...
« Reply #9 on: November 25, 2021, 06:16:29 am »
HotBluePlates is giving you a good way to be thinking about this project.
I'll offer another idea for your consideration.  Use a vintage 5Y3GT for your rectifier, that would give you closer to 348v on the power tube plates. Using the VVR, you may be able to dial those volts down under 300v?   I might add that I always VVR'd  the plates, screens and phase invertor.
IF so, you can try 6K6 tubes for closer to 7watts of power instead of the 6L6's that might be pushing around 23w of power?  Just a thought to consider and I am NOT saying this is something you "should" do.
Still, HBP makes an excellent point that 7 watts will still be quite LOUD.
This song was recorded using a VVR and the volume was less than I typically have on my TV and was a volume that one could still carry on a conversation reasonably easily:
Bluesy Story by Jeff S S | SoundClick
This song was recorded using 6K6 tubes
6K6 & some change by Jeff S S | SoundClick
With respect, 10thtx
Offline 1blueheron
« Reply #10 on: November 26, 2021, 07:50:36 am »
All the feedback has had me doing a lot of thread reading, thinking and trying to distill the heaps of information.
My conclusion at this point: I might be attempting to build the world's most inefficient guitar amplifier.   A Pentodes rather than all triodes in the pre-amp section and perhaps Pentodes wired as triodes in the Output section and a very inefficient speaker.
We currently run this amp on a 2X12 cab. Speakers are stolen from Johnson Mirage JT50. If I would say they are some type of JBL clones.   I have no idea what the SPL rating is on the speakers, but we like the way they sound and they have become our reference cab.
All speaker efficiency numbers I have seen published are standardized as XXdb SPL 1W/1M.  Most guitar speakers have efficiency ratings in excess of 95dB.  It seems difficult to source a low efficiency guitar speaker, let alone one that sounds good.  I realize it is unrealistic to get output tubes designed for clean output up to 45W to provide a pleasant distortion while operating at an output of less than 1 watt and reducing speaker efficiency is probably one of the most efficient ways to quiet an amp regardless of the size and power.   I will keep my eyes peeled for an inefficient speaker.  (thinking of that, I do have an old field coil speaker floating about somewhere that might be an interesting addition to the mix)
I also realize I am not the first to pursuit the Holy Grail of guitar amps and many, more capable than I have come up empty,  and broke when it comes to getting an amp to pleasantly distort at room volume levels and still be useable to gig.  Most amps that  achieve distortion at room volume levels end up becoming one trick ponies incapable of much else lacking versatility.  It is a high bar.
The amp that I feel best represents what I am trying to achieve right now is the PRS MT15.   My son has played on it, and it is amazingly versatile, touch sensitive, and dynamic. I find it particularly interesting as it is billed as a 15w amp but it is 6L6 based. I understand it actually has a power output of roughly 24W.  It runs at a reduced plate voltage of roughly 300V from what I can gather.
It appears most all of the desired distortion is in the preamp and PI stages (6 12AX7's) and they left the 6L6 tubes to do what they do best which is clean amplification.   There is also an attenuator switch to cut it to "7W".
So my thought process here is to develop all of the "tone" in the preamp stages, and not need to push the Output tubes into the stratosphere to obtain heavenly sweetness.  Once again, my knowledge and experience is limited and I draw more from a sound reinforcement and hi-fi background than as a guitar player.
One way of making the 6L6 output tubes super clean at low volume, and reduce max power output is to run them in triode mode. For a guitar amp manufacturer, this would be a costly and counter intuitive approach.  However, if you are just looking for the output section to serve as minimal sound reinforcement and are developing all the "tone" in the pre-amp section, is it not possible that this could be a good thing? It is something I wish to explore but am not decided on.  I am fine with pentode mode output and some form of master volume but I don't expect to push the output tubes into distortion at low volumes, rather just serve as volume control.
I understand that "tone goodness" of rock and roll comes from Pentodes as PRR has pointed out.  So If I want rock and roll goodness, I need to employ pentode distortion somewhere in the circuit.  I understand the the 12AX7/6SL7 is one of the most efficient tubes for obtaining high gain with the fewest number of sockets.  I understand that many experienced builders and players say that a pentode in the pre-amp section creates a superior tone to triodes, but it is less efficient in terms of sockets when it comes to gain stages and driving tone controls and works best with some sort of cathode follower.
I have heard many players say octal tubes sound better than noval.  Since I have this octal amp at my disposal, and it has reasonable voltages to work with, I would like to adapt it for my purposes, hoping it might offer a sonic edge over 12AX7 variants.
How about this.  V1= 5879 with volume control and bass cut > V2 6SL7, with vol control between cascaded triodes followed by > V3 5879 whcih will hopefully at this point be able to be pushed into pentode distortion, which would be followed by a simple volume control and drive the >V4 6SL7 PI.   Treble control would be post PI as a treble cut.   As I see it, this would provide at least 4 gain stages before the PI.  I will redo schematic today to try and reflect my current thoughts.
I believe the transformer on this old organ amp is capable of handling the additional small tubes, will likely convert the pilot light to an LED and save the needed current there.
