August 01, 2026, 02:56:19 am
Hoffman Amps Forum image Author Topic: GIA20G(U65G) low volume noise  (Read 24083 times)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« on: December 02, 2021, 12:48:41 pm »
Hi guys !
Giannini GIA20G
This amp was gifted to me, and wasn't working, it was a bit messy, loose wires and components, I've replaced the power transistor (TIP41C) for TIP41 what I have, all power transistors were busted. Also replaced one of the electrolytic caps, way out of spec.
The amp works, all pot controls work, but the amp have low power/volume, it is a bit noisy ground like noise and sound come out distorted.
So I got to the point where I 'm not sure how to proceed. I appreciate some guidance, thanks in advance.
https://soundcloud.com/ukiuki
Re: GIA20G(U65G) low volume noise
« Reply #1 on: December 02, 2021, 01:58:42 pm »
Schematic? Voltages?
Offline uki
    • Uki's Guitar Trip
« Reply #2 on: December 02, 2021, 02:13:33 pm »
Thanks PRR !
The schem is attached in the 1st post, where to ready the voltages ?
« Reply #3 on: December 02, 2021, 03:49:01 pm »
The schem is attached in the 1st post, ....
The schematics not in that link.    :dontknow:
« Reply #4 on: December 02, 2021, 05:17:21 pm »
It's in the link directly above the pics.
« Reply #6 on: December 03, 2021, 12:04:54 am »
Three blind mice? Here it is as a GIF:
Offline uki
    • Uki's Guitar Trip
« Reply #7 on: December 03, 2021, 05:20:32 am »
Voltages from PT and transistors:
PT primary input 115vac , secondary 22vac each side and 44.4vac across the whole winding.
Q1,Q2,Q6 and Q7 are BC549C
Q1 B 0.8vdc  C 6.8vdc   E 0.2vdc
Q2 B 6.2vdc  C 8.4vdc   E 5.8vdc
Q6 B 1-3vdc  C 0vdc   E 0vdc
Q7 B 0.6vdc  C 3-11vdc   E 0vdc
Q3, Q4 and Q5 are TIP41
Q3 B 8.3vdc  C 27.8vdc   E 7.8vdc
Q4 B 14.8vdc  C 29vdc   E 14.4vdc
Q5 B 0vdc  C 14.3vdc   E 0vdc
Anything else to read?
« Reply #8 on: December 03, 2021, 08:03:45 am »
might take a second, ohm the PI transformer, primary and both secondary's
If you have a scope, or access to a scope might be a good time to bring it into play
Offline uki
    • Uki's Guitar Trip
« Reply #9 on: December 03, 2021, 12:08:28 pm »
PI transformer ohms
primary  31.7 ohms
secondary 5.7 ohms both sides
about same reading connected and disconnected.
no scope
« Reply #10 on: December 03, 2021, 05:17:11 pm »
Q5 base should not be ZERO. It should get a small positive voltage (half Volt?) through the transformer from the resistors. If truly zero it will sound like crap. Find where that's gone wrong.
Offline uki
    • Uki's Guitar Trip
« Reply #11 on: December 04, 2021, 04:06:11 am »
__ It should get a small positive voltage (half Volt?) through the transformer from the resistors.
Ok got new reading and indeed it does have about half volt, 0.48 vdc at Q5 base
« Reply #12 on: December 04, 2021, 05:21:32 am »
without a scope you're down to building a listening amp to trace the signal or shot-gun each stage with new parts, testing after each stage is "be-build"
Offline uki
    • Uki's Guitar Trip
« Reply #13 on: December 04, 2021, 04:40:04 pm »
A little more info about the amp, besides what is in the 1st post, the 3 input wires were connected to one input jack(probably a bad idea), the other 2 jacks were missing, fuse was blow.
Besides using a scope and shotgun method, what else could be done, what could be the most suspicious components? coupling caps ?
« Reply #14 on: December 05, 2021, 08:30:38 am »
a listening amp might help.
headphone amp, small tube amp, old boom-box with a headphone jack will all work.
the idea is to inject a clean known signal, looped song, etc. into your bloke amp, then probe the listening amp along the signal path til you get the uglies.  then it's basically re-build that section and re-test..
shot-gunning parts, I always start with caps, both Ecaps and couplers, then active components, tubes, transistors, IC's. Resistors get ohmed and replaced if they have drifted, look stressed, crusty.
Offline uki
    • Uki's Guitar Trip
« Reply #15 on: December 05, 2021, 09:39:09 am »
Connect the output signal from the stage to the listening amp yes? ground and signal path to the listening amp input ?
« Reply #16 on: December 05, 2021, 10:13:57 am »
you need a "probe" for the listening amp.  shielded wire cable, center conductor is the "probe" (signal), shield goes to ground.
you need a coupling cap between the probe tip and the center conductor in case what you're probing has DCV.  Any cap from .02 - .1uF should be fine.
this "probe" goes into your listening amps input, the output can be a speaker if it's another amp, or headphone amp you just wear the headphones to listen.
on a transistor amp i typically start at the base of the 1st transistor in from the input jack, then move to the collector, find the next stage, repeat. til you hear the distortion.
it takes some practice so don't just jump down a rabbit hole because something just got scratchy, crackly.  try and discern if that sound was your setup, or real
« Reply #17 on: December 05, 2021, 10:21:21 am »
I strongly advise not to use headphones, unless you're willing to blow a hole in your eardrums.   :icon_biggrin:
« Reply #18 on: December 05, 2021, 11:36:31 am »
 :laugh:
most headphone amps have a volume pot, ANY other amp, ya, a speaker is best
« Reply #19 on: December 05, 2021, 12:08:36 pm »
:laugh:
Of course they do. And you inject a suitable signal into the busted amp, connect the listening amp probe to the base of the first xsistor, and adjust the headset volume for a pleasing ear level. Then you move the probe to the collector and BOOM! My ears hurt. About the same thing as you laying on the sofa silently listening to Made in Japan and your dorky little brother walks in and cranks up the amp volume!
Now if you were doing this with a guitar amp as your listening amp, about all that would happen is all the cats would disappear! And that's a good thing. Right!   :l2:
Offline uki
    • Uki's Guitar Trip
« Reply #20 on: December 05, 2021, 12:13:49 pm »
Cool thanks!!  I'll do the suggested listening method ill take some time on it.
Oh hey I manage to get a "scope", well sort of  :icon_biggrin:
https://manpages.ubuntu.com/manpages/bionic/man1/xoscope.1.html
« Reply #21 on: December 05, 2021, 12:23:43 pm »
Hmm, I'd keep looking.
« Reply #22 on: December 05, 2021, 04:19:20 pm »
That uses your sound card. A sick amp and and a sound-card can make disaster. There ARE $30 mini-'scopes that do not risk your PC.
I did manage to install it in a new MXlinux. Doesn't dance but sound under Linux or Oracle VM is goofy at best. Gad, this linux won't even use the same screen resolution twice.
« Last Edit: December 05, 2021, 04:43:15 pm by PRR »
Offline uki
    • Uki's Guitar Trip
« Reply #23 on: December 05, 2021, 06:50:46 pm »
It does need the guest addition thing to be able to run on full screen or any resolution or window size you like.
Found another scope software. Pulseview looks more advanced than the xoscope.
Offline uki
    • Uki's Guitar Trip
« Reply #24 on: December 06, 2021, 05:42:06 am »
Got the Xoscope working with a function generator app on cellphone!
What if the signal is pulled from the headphones output from the listening amp to the computer? would that work w/o risking the computer?
« Reply #25 on: December 06, 2021, 08:13:14 am »
it should
the problem is signal amplitude that's being monitored,(your broke amp), will/could be greater than the sound cards max input allows.
Even if it doesn't smoke the card because of internal protection, you won't have usable results/signal, since it's "clipped" to be safe.
Offline uki
    • Uki's Guitar Trip
« Reply #26 on: December 06, 2021, 02:40:21 pm »
Ok now this looks very interesting, Buffer Hardware for xoscope.
I did the listening amp method, the first stage before Q1 and its base and collector sounds fairly clear.
Gets messy on the tone control stage, very noise and distorted as it gets close to Q2, base and collector are very noisy, I did check Q2 its working, it looks like something between volume pot and Q2 gone wrong, if I'm getting this right.
Offline uki
    • Uki's Guitar Trip
« Reply #27 on: December 08, 2021, 11:30:15 am »
Just realized the amp is about 40 years old, the cab was totally roten, no recovery.
I've replaced some of the electrolytic caps, those were leaking:
C5, C9, C10, C13, C16, C22, C24
although the amp is sounding better, there is still a strong hum. what to do?
« Reply #28 on: December 08, 2021, 01:07:09 pm »
hum is the same whether sand or glass.
what happens when you put a metal "box" over the board?
what happens when you kinda sorta "wave you hand" over the circuit board, or touch one of the pots?
the circuit is either picking up "Noise", creating it then amplifying, the PS isn't filtered/grounded very well
look at the jacks, are they grounding type?  do they indeed "close"?
« Reply #29 on: December 08, 2021, 04:11:13 pm »
Just realized the amp is about 40 years old...still a strong hum. what to do?
The schematic is practically 1960, though the parts are a bit later. But could be 50 years old. And not the best-built product of 1971; indeed it looks cheap.
Hum: what affects it? Physical location? Metal box/not? Change with knobs is a BIG clue where it is getting in.
Offline uki
    • Uki's Guitar Trip
« Reply #30 on: December 08, 2021, 04:55:10 pm »
You are probably right! This amp is been reissued with different names, but same circuit, musicians around here by the time it was popular called it "baguinho". Indeed it is a cheap amp !!
Quote from: PRR
Last time i got the change to work on the amp it was on top of the bench, w/o the chassis, that is probably one factor;
Touching the treble and bass pots does alter the noise(no knobs in place), noise increase as volume goes up;
The board was doing some noise while moving the hand above it in the tone controls area, like from volume to tremolo;
Jacks are for sure another factor, one is missing didn't find one yet to replace, the other two only one have switch and the one that doesn't have switch still need ground. jack with switch on all inputs?
Had no idea about to put a metal box on top if it, with the amp in the chassis, noise was just a lil better.
The most of the noise is something like no ground noise or like when it comes from the electricity installation.
I did capture the frequency from the speaker with a tuner, it was giving 600Hz frequency.
« Reply #31 on: December 08, 2021, 05:15:28 pm »
No. Use only one switched jack. Notice the different values for the mixing resistors? Those resistors and the one switched jack work together to kinda equalize the different input levels for guitar, mic, and organ.
Offline uki
    • Uki's Guitar Trip
« Reply #32 on: December 09, 2021, 02:24:52 pm »
I did assembly the amp in the chassis to see if grounding it all would help, it works alright, no noise!
Thank you very much guys!!
Offline uki
    • Uki's Guitar Trip
« Reply #33 on: January 20, 2022, 02:31:58 pm »
All done now !!
« Last Edit: February 04, 2022, 06:23:16 pm by uki »
