September 19, 2026, 06:06:14 pm
Hoffman Amps Forum image Author Topic: power tube 1 ohm to ground confusion  (Read 8014 times)
Offline joesatch
  • save me from myself.
« on: December 12, 2021, 07:35:55 pm »
I have seen two different variations of this and don't know which one to implement (using EL34 or KT77). What are the differences here?
« Last Edit: December 12, 2021, 07:39:11 pm by joesatch »
Offline jordan86
Re: power tube 1 ohm to ground confusion
« Reply #1 on: December 12, 2021, 08:41:50 pm »
I can’t see where pin 1 goes to in the 2nd image, but I will assume to ground. In which case these are functionally the same. Tying pins 8 and 1 together, and to ground. I imagine someone would do #2 scenario if they had a long run to a power amp ground further away. Allows you to neatly tuck the 1 ohm resistor on the socket and do a long wire run to a different ground point.
Offline joesatch
« Reply #2 on: December 12, 2021, 09:01:43 pm »
yes the black runs to ground. so i guess there is no difference in running the resistor between pin 1 and 8 vs running it off one of the pins with pin 1 and 8 tied together?
« Last Edit: December 12, 2021, 09:05:41 pm by joesatch »
Offline glass54
« Reply #3 on: December 12, 2021, 10:19:33 pm »
Joe
Can be done either way depends on the circumstances.
Have a look at Hoffman AB763_2 (https://el34world.com/Hoffman/files/Hoffman_AB763_2.pdf)
With the Long (turret) board, the 1R are placed "onboard" and wired as indicated
However with the Short board, the option is a suitable earth point, eg fit 1R from pin 8 to lug on Octal socket.
Regards
Mirek
"To measure is to know"
Offline joesatch
« Reply #4 on: December 12, 2021, 10:39:08 pm »
i've gone with the second option. seems like a more solid ground than depending on the resistor lead
Offline Latole
« Reply #5 on: December 13, 2021, 03:52:32 am »
The best way to do it
« Reply #6 on: December 13, 2021, 08:15:36 am »
That kinda implies using the chassis as a conductor for circuit 0V, so not really, but each to their own  :icon_biggrin:
However, in the case of EL34, it’s inappropriate; note that pin1 is assigned to g3.
« Last Edit: December 13, 2021, 11:35:33 am by pdf64 »
Offline Latole
« Reply #7 on: December 13, 2021, 11:59:56 am »
Chassis or ground or common......name it .
« Reply #8 on: December 14, 2021, 03:45:20 pm »
You're ignoring the only point of the original question was the connection from Pin 8 (cathode) to Pin 1 (Suppressor Grid) for EL34.
Your diagram shows Pin 1 being used as a mounting point for the screen resistor, which then runs to Pin 4 and has high positive voltage present on Pin 1.  That's a complete non-starter for EL34.
There are also times where the amp manufacturer does not use the chassis for ground connection/circuit common, and adding circuit common connections to the chassis will create a ground loop and hum (old Ampeg amps are notorious for this).
Offline Latole
« Reply #9 on: December 15, 2021, 03:29:15 am »
All of these are easy to mods.
« Reply #10 on: December 15, 2021, 04:48:13 am »
‘Easy to’ mods are still easy to feck up  :icon_biggrin:
Offline joesatch
« Reply #11 on: March 18, 2022, 11:31:10 am »
Still confusion about this. Normally the ground pin is Pin 8. Running this 1 ohm resistor like this is bypassing that ground how should this be wired?
« Reply #12 on: March 18, 2022, 11:44:03 am »
#1 is correct. #2 does nothing.
Offline joesatch
« Reply #13 on: March 18, 2022, 12:44:30 pm »
fabulous. i dont have to unsolder anything.   :l2:
« Reply #14 on: March 18, 2022, 01:01:50 pm »
Of course my reply depends on my assumption that the black wire on pin 1 is connected to ground.
Offline joesatch
« Reply #15 on: March 18, 2022, 01:10:51 pm »
indeed  :icon_biggrin:
Offline Dyerseve726
« Reply #16 on: March 18, 2022, 06:16:44 pm »
The idea is to put the 1 ohm resistor between the cathode and ground (in a fixed bias amp). The other pin is just being used as a support for the resistor. I just run a wire off pin 8 to some banana plugs and hang the resistor between them, see the photo.
