August 29, 2026, 08:27:24 pm
Hoffman Amps Forum image Author Topic: IEC plug wiring  (Read 4849 times)
Offline joesatch
  • save me from myself.
IEC plug wiring
« on: December 15, 2021, 12:28:20 pm »
I wasn't aware you could swap Hot and Neutral into the PT. In this diagram they have it twisted ( i assume they believe it doesn't matter?). I'm concerned.
Re: IEC plug wiring
« Reply #1 on: December 15, 2021, 01:14:35 pm »
The transformer doesn't care.
Your snip is missing information, but I'll assume that the twisted blacks are going to a power switch that switches both primary legs at the same time.
So, the switch doesn't care either.
As long as you've got the "HOT" going to the fuse then you have satisfied the amp gods.
Offline joesatch
Re: IEC plug wiring
« Reply #2 on: December 15, 2021, 01:52:26 pm »
what's the twisting do?
Re: IEC plug wiring
« Reply #3 on: December 15, 2021, 02:08:42 pm »
Re: IEC plug wiring
« Reply #4 on: December 15, 2021, 02:43:05 pm »
Looks good.
    :laugh:
It helps cancel magnetic field radiation from current running through the wires that can be injected into other wires/circuitry causing noise/hum.
« Last Edit: December 15, 2021, 02:46:27 pm by Willabe »
