September 17, 2026, 02:33:51 am
Hoffman Amps Forum image Author Topic: Self-adhesive tie mounts for wire routing  (Read 4763 times)
Offline PharmRock
« on: January 04, 2022, 07:14:09 pm »
A while back I started a thread about the Dr. Z "EMS" amp and I noticed in the gut shots he used these little adhesive tie mounts for wire routing.  I figured if he's doing it, why not give it a shot myself?
I ordered a bag of 200 off Amazon for about $10, the 1/2" x 1/2" size.
these are perfect for the little 4" wire ties.
was wondering if any of experienced builders have used them in your builds and how the adhesive held over time.  A little worried about the heat un-stickyfying the little pads.
Re: Self-adhesive tie mounts for wire routing
« Reply #1 on: January 04, 2022, 07:28:30 pm »
They usually do well in a temperature/humidity controlled environment. Not so good in a power panel outside your house.
Offline bmccowan
  • Better builder than player
« Reply #2 on: January 04, 2022, 09:33:36 pm »
I have used those and the next size up in quite a few amps - especially when drilling holes is just not a good idea. I like them for securing axial filter caps. I clean the chassis area first with alcohol - Isopropyl, not Lagavulin. They hold well, but where I can, I prefer to drill a hole and secure the pad or use another type of mount - lots of options here https://www.cabletiesandmore.com/cable-supports. What I have never liked is using a glob of RTV to secure things and these pads help avoid that.
Mac
John Prine
Offline PharmRock
« Reply #3 on: January 04, 2022, 10:50:13 pm »
I can see where using the ones with mounting holes would come in really handy.  decent price too.
« Reply #4 on: January 05, 2022, 08:03:37 pm »
What I have never liked is using a glob of RTV to secure things...
Same
