September 16, 2026, 12:46:20 am
Hoffman Amps Forum image Author Topic: Are Fender and Marshall Transformers interchangeable?  (Read 5882 times)
Offline joesatch
  • save me from myself.
« on: January 13, 2022, 03:09:18 pm »
Let's say i wanted to replace a JTM45 Power Transformer but have come across a Fender PT rated somewhat similarly but very cheap in price. Would this work? Same with the OT ?
Re: Are Fender and Marshall Transformers interchangeable?
« Reply #1 on: January 13, 2022, 03:32:16 pm »
yes yes
« Reply #2 on: January 13, 2022, 04:35:01 pm »
Fender PTs often seem to have their ratings expressed in a different way to Marshall. So make sure to compare like with like. eg the typical Marshall 700V@150mA is probably a ‘point on the curve’, rather than the max load.
« Reply #3 on: January 13, 2022, 05:20:50 pm »
Would you define 700V@150mA is probably a ‘point on the curve’?
I don't think it is understood by many here including me.  :laugh:
« Reply #4 on: January 13, 2022, 06:01:12 pm »
I meant that 150mA probably isn’t the max rated current. So 700V@150mA means that when loaded at 150mA, the voltage will be 700V. At lower loads, the voltage will be higher, at higher loading, it will be lower. A typical 2xEL34 with a 3k5ish primary OT and a HT voltage of about 420V at max unclipped output will probably draw more than 150mA.
Offline dwinstonwood
« Reply #5 on: January 13, 2022, 10:43:38 pm »
As much as I've read on OPT's this is still a point of confusion for me. Is there an "explanation for dummies" for how and why OPT primary impedance affects power tube current draw? If I used a 6,600 OPT with two 6V6GT's would the current draw be more of less if I used an 8,400 OPT?
Thanks!
« Reply #6 on: January 14, 2022, 12:27:00 am »
Dummy thought experiment:
300V across 6600Ω is 0.045A
300V across 8400Ω is 0.036A
Those are not final answers. There's two sides to the Push-Pull winding, and we assume sine-waves not steady DC. But the trend is right.
