September 08, 2026, 12:07:52 pm
Hoffman Amps Forum image Author Topic: Two 4 ohm speakers in series or parallel read 2 ohm on multimeter  (Read 6473 times)
Offline BurjorDastur
I have two 4 ohm speakers that I want to wire in series for 8 ohms.
I have tried both series and parallel wiring and it always reads 2 ohms on the multimeter.
I understand that the multimeter will not be exact and there is a general formula where the reading will be below the speaker ohm rating.
I have wired some 8 ohm speakers together and got readings that made sense 13 ohms in series and 4 ohms in parallel. However the two 4 ohm speakers together always read 2 ohms whether they are wired in series or parallel.
Any help would be appreciated.
Re: Two 4 ohm speakers in series or parallel read 2 ohm on multimeter
« Reply #1 on: January 19, 2022, 03:00:02 pm »
I'd say operator error or faulty meter. Maybe replace meter battery.
« Reply #2 on: January 19, 2022, 03:24:03 pm »
this
also, compare against a "standard"
What does a 10 ohm resistor ohm?
« Reply #3 on: January 19, 2022, 07:09:31 pm »
Sluckey, Sir you are correct. Operator error.
Thank you and shooter for replying.
