September 16, 2026, 03:18:40 pm
Hoffman Amps Forum image Author Topic: Clean Booster  (Read 6260 times)
Offline Leevi
    • Rikstone
Clean Booster
« on: February 09, 2022, 11:02:40 am »
I built the following clean booster for 6SN7 or 6SL7.The idea is to keep the sound as clean as possible. There is not that much gain but the signal looks very nice and clean.I'm asking some comments and possible improvements?
/Leevi
Re: Clean Booster
« Reply #1 on: February 09, 2022, 06:49:06 pm »
What is the voltage at "A"?
What voltages do you have that the cathodes?
Why have a plate load for the 2nd stage, but also a large cathode resistor?
« Last Edit: February 10, 2022, 05:46:01 am by HotBluePlates »
Offline Leevi
    • Rikstone
Re: Clean Booster
« Reply #2 on: February 09, 2022, 10:54:39 pm »
A = 312V Plate (triode 1)  299V Plate (triode 2) 232V Cathode (triode 1) 2.5V Cathode (triode 2) 5V
Why have a late load for the 2nd stage?
No idea, it's probably not needed?
..but also a large cathode resistor?
what is an optimal value of the cathode resistor without load resistor?
/Leevi
« Last Edit: February 09, 2022, 10:59:36 pm by Leevi »
Re: Clean Booster
« Reply #3 on: February 10, 2022, 12:06:39 am »
> A = 312V
These as not making sense, so much that I fear I am mis-reading your compact data.
What do you want it to do better? Play clean? Distort badly? Make coffee?
Offline Leevi
    • Rikstone
Re: Clean Booster
« Reply #4 on: February 10, 2022, 12:52:55 am »
I made a new check and unfortunately the triode numbering was wrong in my previous post. Sorry for that.You are right PRR.
Corrected values:
> A = 312V
> Plate (triode 1)  232V
> Plate (triode 2) 299V
Play clean with max gain without distortion
Situation on max. volume,  input: blue, output: yellow
Note! the signal is inverted in the scope.
The tube is 6SL7
/Leevi
« Last Edit: February 10, 2022, 05:04:19 am by Leevi »
Re: Clean Booster
« Reply #5 on: February 10, 2022, 12:22:46 pm »
Eventually *something* in the system will distort. Or if "gain" is to bring-up soft playing, something will hiss.
The easy path to more gain is a 6SL7 and a 22uFd cap on the first capacitor {edit: Cathode}.
That gain/volume control connection is unusual.
I checked that your readings add-up; they do (close enough). As was said, the plate resistor on the cathode follower is not needed and maybe not wanted.
« Last Edit: February 10, 2022, 08:08:38 pm by PRR »
Offline Leevi
    • Rikstone
Re: Clean Booster
« Reply #6 on: February 10, 2022, 01:00:01 pm »
Thanks for the analysis PRR
The easy path to more gain is a 6SL7 and a 22uFd cap on the first capacitor.
You probably mean the first cathode?
Yes, it is. The first triode works as a volume driver. And this kind of connection of the pot does not change the sound (no serial resistor)
I already removed it
I'm planning to increase the cathode resistor to 56K which probably adds gain a bit.
Re: Clean Booster
« Reply #7 on: February 10, 2022, 08:12:37 pm »
...I'm planning to increase the cathode resistor to 56K which probably adds gain a bit.
It's a cathode follower! Gain is something less than unity, and not much affected by circuit values. Pencil "0.9", though it can be 0.98, not much difference.
It is a "ground biased" cathode follower. So it can only take a volt or three of down-swing before clipping. Bias it up and then it can swing big down-swings. But already it can clobber almost any guitar amp input. Which comes back to What Do You Want?? Actual gain, so you can use a rose pedal pick to play loud? Or "dirt", the usual side-effect of excess gain?
« Last Edit: February 10, 2022, 09:25:48 pm by PRR »
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: Clean Booster
« Reply #8 on: February 11, 2022, 07:47:53 am »
I like the idea !   Is it a pedal or stage on amp ?
https://soundcloud.com/ukiuki
Offline Leevi
    • Rikstone
Re: Clean Booster
« Reply #9 on: February 11, 2022, 12:05:07 pm »
The idea is to use it as a  pedal and the first version is more like a proto.
/Leevi
Offline uki
    • Uki's Guitar Trip
Re: Clean Booster
« Reply #10 on: February 13, 2022, 07:37:51 pm »
Could it work as amp stage as well ?
« Last Edit: February 13, 2022, 07:42:46 pm by uki »
Offline Leevi
    • Rikstone
Re: Clean Booster
« Reply #11 on: February 14, 2022, 02:52:51 am »
Yes, definitely
/Leevi
