September 17, 2026, 04:21:48 am
Hoffman Amps Forum image Author Topic: Massive resistor after Primary filter caps.  (Read 6896 times)
Offline joesatch
  • save me from myself.
« on: March 27, 2022, 04:55:31 pm »
What is this 10W 400R dale resistor for?
Re: Massive resistor after Primary filter caps.
« Reply #1 on: March 27, 2022, 05:46:11 pm »
That's between the plate and screen supply nodes, so its part of the R/C filtering
« Last Edit: March 27, 2022, 10:26:57 pm by tubeswell »
« Reply #2 on: March 27, 2022, 05:46:41 pm »
It's purpose is to drop voltage to the rest of the B+ string. 400Ω/10W is not MASSIVE.
« Reply #3 on: March 27, 2022, 05:55:43 pm »
I used I^2 R
100mA^2*400 = 4W
that's probably in the danger zone for the stuff downstream to be pullin
« Reply #4 on: March 27, 2022, 06:11:32 pm »
I used I^2 R
100mA^2*400 = 4W
Did you just make up those numbers? You ain't out in the bait shop are you? :wink:
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #5 on: March 27, 2022, 06:16:09 pm »
this is massive !!
https://soundcloud.com/ukiuki
Offline joesatch
« Reply #6 on: March 27, 2022, 09:37:33 pm »
i believe i found the answer on the interwebs..
Offline thetragichero
« Reply #7 on: March 27, 2022, 10:23:16 pm »
it is certainly cheaper, but can also be a design choice
Offline AmberB
« Reply #8 on: March 27, 2022, 11:43:08 pm »
Pretty much standard procedure for Bogan tube amps...I've never seen one with a choke.
« Reply #9 on: March 28, 2022, 01:58:22 am »
If the position of the resistor on the schematic will be before the first node, also because on the schematic are indicated parallel connection, the purpose of that resistor can be SAG resistor (also the resistence value is compatible)
but as it is after the first node the only explanation is that to which refers Sluckey
« Last Edit: March 28, 2022, 02:22:38 am by kagliostro »
« Reply #10 on: March 28, 2022, 03:40:57 am »
out ain't out in the bait shop are you?
:laugh:
there is logic behind the #'s
I was "looking" for 5W, then double n ship!
but to answer the ?   :icon_biggrin:
Aside
we used foot long 1" diameter Resistors in a large Amp PS, they were ceramic coated, the PS's typical fail started with the Ceramic melting off and it goes down-hill from there!
Offline AmberB
« Reply #11 on: March 29, 2022, 03:18:28 am »
When the ceramic melts off your resistors, you definitely have a problem...
« Reply #12 on: April 05, 2022, 12:20:13 pm »
 :huh:             :l2:
« Reply #13 on: April 05, 2022, 01:11:01 pm »
I looked for the pics but they are lost in space
the heat on the top of the box was enough to melt the Aluminum, and "etch" really nice colors into the cover.
I did a painting of it n gave it to the Boss   :icon_biggrin:
the box was so hot I just left it for 12hrs.
after the field reported many such cases the real Engineers finally put down their coffee and came up with a fix.
