September 18, 2026, 06:39:44 am
Hoffman Amps Forum image Author Topic: help identify which tubes  (Read 5727 times)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« on: April 29, 2022, 12:40:32 pm »
Hey guys !!
Which PA tubes could be used in the following circuit(may be wrong)?
The B+ I'm guessing something around 420v rectified by 5y3(gt maybe), PT 350-0-350.
Thanks in advance !
https://soundcloud.com/ukiuki
Re: help identify which tubes
« Reply #1 on: April 29, 2022, 01:10:15 pm »
Pinout corresponds with 6L6 tubes but also EL34
Voltage is compatible with both tubes if I remember well
« Last Edit: April 29, 2022, 01:15:49 pm by kagliostro »
Offline uki
    • Uki's Guitar Trip
« Reply #2 on: April 29, 2022, 06:31:16 pm »
Thanks Franco, that is what I was thinking, much appreciated !
« Reply #3 on: April 30, 2022, 10:11:07 am »
5Y3 won’t supply enough forward current to make a pair of 6L6s sound good. Cathode-biased 6V6s will sound happy.
A 5AR4 will work in the same 5V 2A winding and will work good with a pair of 6L6s, provided that the High Tension winding can deliver at least around 180mA (preferably 200mA)
« Last Edit: April 30, 2022, 10:47:14 am by tubeswell »
Offline uki
    • Uki's Guitar Trip
« Reply #4 on: May 01, 2022, 08:29:55 am »
The PT
pri  115v 50cy
sec 350-0-350 200mA
5v 4A
6.3v 5A CT
Offline luthierwnc
  • Should I mod this one or make another?
« Reply #5 on: May 01, 2022, 11:07:43 am »
I would have guessed EL34 because of the 1k screen resistor.  And yes, a 5Y3 won't get it done.  When in doubt, I always look at the Duncan power supply calculator: http://www.duncanamps.com/psud2/  sh
« Reply #6 on: May 01, 2022, 01:40:39 pm »
I would have guessed EL34 because of the 1k screen resistor.  ...
"1kΩ screen resistor" doesn't really mean anything.  Any tube could potentially have that value screen resistor.
That there is no indication Pin 1 (EL34 Suppressor) is tied to Pin 8 (EL34 cathode) is a strong indication it is not an EL34.  That link is mandatory, except when the suppressor is tied to a negative voltage.
