September 15, 2026, 08:35:15 am
Hoffman Amps Forum image Author Topic: Balance and variable bias system at the same time?  (Read 6417 times)
Offline 72Blazer
  • Long live rock!
« on: April 30, 2022, 04:43:56 pm »
I have some unmatched 6L6s and 6V6s.  I seem to recall a thread earlier this year that showed a fender type amp with both balance and variable bias systems installed.  I think Sluckey posted it.  I can't locate the thread that showed that if in fact I am recalling this correctly.  Anybody recall this or have a layout for this?
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: Balance and variable bias system at the same time?
« Reply #1 on: April 30, 2022, 06:50:21 pm »
Rob Robinette have several examples in his page:
https://robrobinette.com/Generic_Tube_Amp_Mods.htm
https://soundcloud.com/ukiuki
Offline Latole
« Reply #2 on: May 01, 2022, 04:36:38 am »
You can built bias circuit with 2 bias pots
« Reply #3 on: May 01, 2022, 04:58:36 am »
I was showing how to add a bias adjust pot to a Fender amp that came equipped with a balance pot. See this thread...
     https://el34world.com/Forum/index.php?topic=28618.msg315226#msg315226
But if you're just wanting separate bias pots for each tube I suggest doing something like I did to my Sunn Sceptre. Your resistor values may be different. See this recent thread...
     https://el34world.com/Forum/index.php?topic=28790.msg316882#msg316882
« Last Edit: May 01, 2022, 05:12:36 am by sluckey »
Offline Latole
« Reply #4 on: May 01, 2022, 07:17:44 am »
If you are ready to install 2 potentiometers, it is probably better to have two bias potentiometers rather than one bias and one balance.
This is what I do for the amps I build
Offline 72Blazer
  • Long live rock!
« Reply #5 on: May 01, 2022, 02:02:10 pm »
Thanks All for the information-much appreciated.
Vr
J.
Offline owen
« Reply #6 on: May 15, 2022, 02:55:26 pm »
I started doing this recently when I got a pile of used tubes.
my exception for one bias and one balance is fixed bias amps with bias-vary tremolo. currently sketching this plan out for my tremolux and princetons.
« Reply #7 on: May 17, 2022, 06:10:01 pm »
... one bias and one balance ...
If you do that system, you turn the balance first to get the tubes even.  Then you turn the bias adjust to set where you want them.
Although some folks have preferences, you're going to adjust 2 pots any way you slice it.
Offline TonyM
« Reply #8 on: May 19, 2022, 08:43:46 am »
I used Rob Robinette's layout with two potentiometer on my jcm 800 2204 build but  I had to change the 56k resistor to a 68k resistor to bring the bias within a balanced adjustable range.
