September 18, 2026, 08:35:28 pm
Hoffman Amps Forum image Author Topic: Vox Ac 15 vibrato problem  (Read 32253 times)
Re: Vox Ac 15 vibrato problem
« Reply #50 on: June 08, 2022, 02:00:18 pm »
I've also been bothered by the positive voltage on pins 2 and 7. So, I put my amp on the bench, set the variac to exactly 120VAC, and warmed the amp for a few minutes. Here are the voltage readings for V4 on a properly working amp...
pin 1 = 73vdc
pin 2 = 0vdc
pin 3 = 3.3vdc
pin 6 = 74vdc
pin 7 = 0vdc
pin 8 = 3.3vdc
I'm beginning to think your board 'may' be conductive. What material is the turret board? Doesn't look like fiberglass. The board looks pretty dirty in that poor quality pic you posted. The turret column spacing is 1/4". That's pretty tight. A clean, high quality board is important.
What brand and model number is your meter?
Offline rafaelctt
« Reply #51 on: June 08, 2022, 02:01:13 pm »
I have measured it with a multimeter in VDC. I will measure it with an oscilloscope
« Last Edit: June 08, 2022, 02:09:34 pm by rafaelctt »
Offline rafaelctt
« Reply #52 on: June 08, 2022, 02:04:17 pm »
Are you sure that’s a VDC (average) measurement, eg rather than instantaneous?
One grid looks to be -2V, the other +2V.
« Last Edit: June 08, 2022, 02:08:57 pm by rafaelctt »
« Reply #53 on: June 08, 2022, 02:10:18 pm »
I have measured it with a multimeter in DC.
No, the question was:
....What brand and model number is your meter?
The meter details matter. Since you may not know the meter's specs, Sluckey wants to help by looking-up the specs of YOUR meter and giving advice accordingly.
If you switch to an oscilloscope, he'll again want to know brand/model. For a short time in the late 20th century, "all 'scopes were the same", but newer ones can be very different. (And some un-suitable for tube amplifier work.)
Offline rafaelctt
« Reply #54 on: June 08, 2022, 02:17:01 pm »
Fluke model 123
Offline rafaelctt
« Reply #55 on: June 08, 2022, 02:25:04 pm »
« Reply #56 on: June 08, 2022, 02:41:59 pm »
When you measure 2vdc on pin 2 or pin 7 is it possible that your scopemeter is really displaying 2mV and you are mistakenly interpreting that as 2V?
We've eliminated all the logical paths for 2vdc to get on the grids. Time to look at some illogical paths such as conductive board. Try this. Connect one meter probe to chassis ground. Now use the other probe to poke the board near the turrets that the V4 components are connected to. You should not measure any voltage on the board at any point.
Offline trobbins
    • Tim's projects and info
« Reply #57 on: June 08, 2022, 08:36:25 pm »
Or reading AC+DC, rather than just the DC mode of the Fluke 123.
Offline rafaelctt
« Reply #58 on: June 09, 2022, 11:20:36 am »
Tomorrow I will do the measurements again with an oscilloscope. Should I do it in VDC or VDC+AC? For these measurements, do I disconnect C24 and C23 or is it not necessary?
I understand that I should get 0V on pin2 and pin7.
I have bought all the components that surround V4 and if I don't get those measurements I will simulate it externally. I'll do it with a 12AX7. I imagine I must also get 0V on those pins.
« Reply #59 on: June 09, 2022, 12:26:35 pm »
VDC only. No need to disconnect anything.
Offline rafaelctt
« Reply #60 on: June 09, 2022, 12:37:31 pm »
Do I leave the V6 connected? Should I take any other precautions? Does the 12AX7 serve me for these measurements?
Thank you
« Reply #61 on: June 09, 2022, 12:58:42 pm »
Put V6 in the socket. No precautions. 12AX7 is OK but a good 12AU7 would be better.
What material is your board?
« Reply #62 on: June 09, 2022, 01:07:52 pm »
It seems to me that if the grid voltage was due to a conductive board (or leaky coupling caps), it would still be there, perhaps even worse, with the valve in V4 pulled?
As it isn’t (see reply #37), I wonder if there’s a error in implementing the circuit, eg missing link, incorrect value resistor?
« Last Edit: June 09, 2022, 01:10:49 pm by pdf64 »
Offline rafaelctt
« Reply #63 on: June 09, 2022, 01:12:31 pm »
This is the only one I found in Spain that would fit the size. The truth is that I did not like it from the beginning.
https://www.retroamplis.com/epages/62070367.sf/sec0beea035dd/?ObjectPath=/Shops/62070367/Products/BO-PHP2-200X400
Offline rafaelctt
« Reply #64 on: June 10, 2022, 06:05:04 am »
I have managed to get it to work at 90%, the vibrato channel already works well, enough volume and without distortion but it has background noise. I have to keep reviewing. It is a problem of lack of insulation at different points on the board. Little by little I am solving them. I have too much input gain on the channels, which gives me distortion in the first stage.
Offline rafaelctt
« Reply #65 on: June 12, 2022, 09:52:30 am »
The problem I have now is the voltage of pin1 of v6. My blood pressure is too low. I have removed the V6 and the tension is correct, but when I put the valve on, the tension drops too much. do you know what it could be?
« Reply #66 on: June 12, 2022, 10:22:37 am »
Read note 1.
Offline rafaelctt
« Reply #67 on: June 12, 2022, 10:28:03 am »
Yes Sluckey, I have R65 and R68 grounded. I just checked again.
« Reply #68 on: June 12, 2022, 10:43:58 am »
NOTE 1: Oscillator voltages taken with oscillator disabled.
By grounding those resistors you have ENABLED the oscillator!
Offline rafaelctt
« Reply #69 on: June 12, 2022, 10:53:53 am »
With the oscillator disabled (r65 and r68 not grounded) the voltage is even lower at pin1. I just measured 71V
Offline rafaelctt
« Reply #70 on: June 12, 2022, 10:57:23 am »
The oscillator does not oscillate. I measure it with the oscilloscope and find no oscillation. n the simulator (Proteus) if it oscillates and I have the same component values
« Reply #71 on: June 12, 2022, 11:30:28 am »
You told me in a PM that you measured 30V on the board, meaning the board is conductive. You are wasting your time doing any further checks. Replace the board with a high quality G-10 fiberglass board and start over.
I understand and sympathize with you since Hoffman won't sell you the board due to the crazy VAT laws. You probably would not pay the price even if Hoffman would sell to you. So, you will have to make your own board again with a better quality board. I know you said you could not find a blank board that's long enough, but you still have options. The board is laid out such that there are several logical places where you could split the board and use two shorter boards. Or, you could cut your losses and use the parts to build another amp that uses a shorter board, such as a Marshall 18W or my Dual Lite.
Offline rafaelctt
« Reply #72 on: June 12, 2022, 11:38:39 am »
Tomorrow I'll start building the circuit around the V6 on a separate board as a prototype. I'll go step by step. The clean circuit works very well and so does the vibrato preamp stage. So I will focus on the V6. Thank you very much. I will inform you.
« Reply #73 on: June 12, 2022, 01:14:00 pm »
Tubetown sell nice boards, 0.5m lengths!
Offline rafaelctt
« Reply #74 on: June 15, 2022, 11:13:05 am »
Hello!! I have already built a simulation of the circuit around V6(oscillator). How can I check with the oscilloscope that it is oscillating? At what frequency and with what voltage does it oscillate and on which pin can I measure it?
Thank you
« Reply #75 on: June 15, 2022, 11:42:04 am »
The oscillator signal is a big sinewave. Frequency is between 3 and 10Hz, depending on the speed pot setting. I suggest setting the speed pot about midrange and set the intensity pot to zero.
Connect your scope to the ungrounded lug of the intensity pot to view the waveform.
Or you may be interested in the LED indicator mod I did to my AC-15. The LED replaces R55 and the anode connects to pin 8 of V6. The LED blinks at the speed of the oscillator and will be steady if the oscillator is disabled or the intensity pot is set to zero. My LED is mounted on the front panel. Look here if interested...
        http://sluckeyamps.com/VAC15/Vox_AC-15.1.pdf
« Reply #76 on: June 15, 2022, 11:45:39 am »
Another way to tell if the oscillator is working is to measure the DCV on V6 pin 1. If the voltage is steady, it ain't working. If the voltage is constantly changing or erratic it is working. The bar graph on your meter should be moving at the speed of the tremolo.
Offline rafaelctt
« Reply #77 on: June 15, 2022, 01:06:52 pm »
I find it fantastic!!
I will also make the led circuit!!
Thank you!
Offline rafaelctt
« Reply #78 on: June 18, 2022, 02:58:31 pm »
Well, it seems that everything has gone well.
I have built it off the board and it has worked perfectly.
With which I only have to implement it on the circuit.
« Reply #79 on: June 18, 2022, 03:52:51 pm »
Does this mean you have built the ENTIRE AMP off board? Could we see pictures?
Offline rafaelctt
« Reply #80 on: June 19, 2022, 11:09:19 am »
No, I have built the vibrato circuit (V6) off the board. the rest the same
Offline rafaelctt
« Reply #81 on: June 21, 2022, 02:05:20 am »
Good morning, a question. I could have a direct output or use the power zone (EL84) with an external jack if I interrupt the central volume contact (R29)?
« Last Edit: June 21, 2022, 02:07:59 am by rafaelctt »
« Reply #82 on: June 21, 2022, 03:41:46 am »
That will work as a power amp input.
As drawn, the signal from that preamp will be disabled when a plug is inserted.
Is that how you want it to work?
« Reply #83 on: June 21, 2022, 09:32:40 am »
You need two jacks if you want a preamp output ***AND*** power amp input available. Notice this does not apply to the VIBRATO channel!
Offline rafaelctt
« Reply #84 on: June 21, 2022, 12:14:39 pm »
Yes, I had thought of that or a jack and switch to use it as a direct out or power amplifier. It could even be used to daisy chain an external effect. Of course it would only work on the clean channel.
Offline Eythor
« Reply #85 on: June 24, 2022, 06:57:01 am »
In case you want to rebuild the board, modulus amps in the UK has boards long enough for this and very affordable shipping. I got this one from him.
