August 29, 2026, 09:12:13 pm
Hoffman Amps Forum image Author Topic: 5w amp scheme with reverb?  (Read 15872 times)
Offline rafaelctt
« on: August 21, 2022, 07:14:33 am »
Hello, can you guide me on a 5w amp scheme to which you can insert a reverb with a 9" tank approximately. Thank you!
Re: 5w amp scheme with reverb?
« Reply #1 on: August 21, 2022, 07:29:50 am »
The first that quickly comes in my mind now are
Gibson GA 1RT 1
https://el34world.com/charts/Schematics/files/Gibson/Gibson_ga_1rt_1.pdf
Gibson GA 1RVT
https://el34world.com/charts/Schematics/files/Gibson/Gibson_ga_1rvt.pdf
BTW Also exist some Champ Reverb amp but those are custom build by passionates
See here
https://el34world.com/Forum/index.php?topic=23328.0
« Last Edit: August 21, 2022, 08:08:44 am by kagliostro »
« Reply #2 on: August 21, 2022, 08:27:55 am »
when i'm wanting "ideas", I ALWAYS start here;
Tube amp Schematics Index Page (el34world.com)
beware, if you like this sport, you may need to limit your exposure, that page can become addictive  :icon_biggrin:
« Reply #3 on: August 21, 2022, 09:39:38 am »
don't know why this image appeared on my mind  :icon_biggrin:
 :bump1:
« Reply #4 on: August 21, 2022, 10:06:25 am »
 :laugh:
that's my brain most mornings, by nighttime i've plowed a giant hole through the maze, just to realize i'm back where I started  :headbang:
Offline rafaelctt
« Reply #5 on: August 23, 2022, 06:05:55 am »
Do you think that such a combination could work? Logically studying changes in resistance values ​​mainly.
It would be the combination of Fender Pricenton preamp and reverb and Vox Ac4 power amp and source
« Reply #6 on: August 23, 2022, 06:48:51 am »
Probably need to include the next gain stage from the PR.
« Reply #7 on: August 23, 2022, 07:03:56 am »
Those on the link I posted Is a proven schem & layout
Offline rafaelctt
« Reply #8 on: August 24, 2022, 02:37:47 am »
I can't get into that forum(ampgarage) as a member. I've tried repeatedly to register, but I can't. Does this information exist elsewhere?
Thank you
Offline zircontweezer
« Reply #9 on: August 24, 2022, 03:26:55 am »
Thank you
All the links in this post seem to be EL34 world open source or did I miss something? Can't see any ampgarage links.
« Reply #10 on: August 24, 2022, 03:39:10 am »
The ampgarage link Is on the thread i linked, however schematic and layout are on the link I posted
« Reply #11 on: August 24, 2022, 05:09:04 am »
grazie  :smiley:
« Reply #12 on: August 24, 2022, 09:29:27 am »
OK, try to conctact an Ampgarage administrator to solve the registration problems
currently read the whole thread on the attached .pdf
« Reply #13 on: August 24, 2022, 09:44:28 am »
Did you read the FAQs?
I sent the administrator a message about this. I'll let you know what he says.
« Reply #14 on: August 24, 2022, 12:46:46 pm »
TAG administrator has set up your account. Here's what he said... "I've activated his account, he's got a gmail account and it seems like due to the messed up state with email on this forum, gmail especially deletes/discards all forum mail. It doesn't even end up in the spam folder so I've been told."
« Last Edit: August 24, 2022, 12:49:17 pm by sluckey »
Offline rafaelctt
« Reply #15 on: August 24, 2022, 05:23:10 pm »
I understand then that I will have to register with an email that is not gmail?
« Reply #16 on: August 24, 2022, 05:31:45 pm »
No. You missed the important part. He has activated your account. I think that means you just need to log in with your name/password.
Offline ac427v
« Reply #17 on: August 24, 2022, 10:00:11 pm »
See if this works
« Reply #18 on: August 24, 2022, 11:53:22 pm »
I built three of these into combo cabinets. See attached - 2 are KT88 versions, the third is a 6L6GC, the schematic attached is to the 6L6GC model. One is a gift for this coming x-mas, the second is mine, the third was promised but individual fell on hard times, so no home for it yet. The KT88 amp pair are driving a JBL D130, and the 6L6GC model (gift amp) is driving a pair of 10" Eminence Red Coat.
The classictone 40-18031 & Allen TO-11A are obviously no longer available, Amp Parts Direct were selling a Heyboer clone of the 40-18031 part, but are sold out now - No telling when or if that part will return. I tested the Musical Power Supplies 12VA SE and it performed well, however, the Allen TO-11A IMO is/was the best sounding overall. The reverb driver I used originally was the Classictone 40-18030 - I replaced that with the Hammond 1750AX with like results. I had several PCB manufactured. Some component changes on the PCB, OT and PT swaps are all that differ from the KT88 and 6L6GC models.
https://www.hammfg.com/files/parts/pdf/1750AX.pdf
https://www.ebay.com/itm/155092204102?hash=item241c373a46:g:LQIAAOSwMXxfjmJ9
https://shop.amppartsdirect.com/collections/apd-custom-by-heyboer/products/fender-champ-style-15w-upgrade-single-ended-4-8-16-ohm-output-transformers-apd-8031h-by-heyboer-transformers-replaced-40-18031
https://www.dropbox.com/s/8xkixymj9k5te2e/20210805_215745.jpg?dl=0
https://www.dropbox.com/s/703a9sep6shwmas/20210805_220435.jpg?dl=0
https://www.dropbox.com/s/u90hfs5ijoj29qa/20201213_162046.jpg?dl=0
https://www.dropbox.com/s/3e658619uvpciqb/20210714_145758.jpg?dl=0
https://www.dropbox.com/s/ocgfrc9yjun10ko/20210712_193614.jpg?dl=0
--Pete
Offline rafaelctt
« Reply #19 on: August 26, 2022, 06:22:05 am »
I have got it!! Thank you!!
Offline rafaelctt
« Reply #20 on: August 26, 2022, 06:24:40 am »
--Pete
My idea is to use semiconductors in rectification (diodes), EL84 as power and short reverb tank.
What PT do you use in this amp?
Offline Williamblake
« Reply #21 on: August 26, 2022, 09:53:11 am »
I wish someone guided me on a 5W amp with reverb but despite good efforts, build a 5w amp and a reverb unit is all they could do. Am still thankfull, though.
« Reply #22 on: August 26, 2022, 12:47:51 pm »
--Pete
PT make and model # noted in schematic. Hammond 272BX
Offline rafaelctt
« Last Edit: August 27, 2022, 01:33:18 am by rafaelctt »
« Reply #24 on: August 27, 2022, 08:40:00 am »
The 290UEX would work but it's overkill for a 5 watt amp. I would rather use the 291AEX.
Offline rafaelctt
« Reply #25 on: August 28, 2022, 11:58:39 am »
I think I'll do that build, with those components. Do you think it could work well? Can I replace the choke with a resistor? Can I replace the rectification valve with diodes? Thank you
« Reply #26 on: August 28, 2022, 12:15:43 pm »
Do you think it could work well?  Yes. May need a little tweaking. I would use an 8AB3C1B tank.
Can I replace the choke with a resistor?  yes
Can I replace the rectification valve with diodes?  yes
« Reply #27 on: August 28, 2022, 01:36:48 pm »
Instead of a choke you can use a resistor
or, a gyrator (that is similar to an inductor)
From Mr. Merlin
(You can find a lot of interesting things on Merlin's Brooks)
« Last Edit: August 28, 2022, 01:41:03 pm by kagliostro »
Offline rafaelctt
« Reply #28 on: August 29, 2022, 04:25:35 am »
Could this scheme be definitive? What diodes do you recommend?
« Reply #29 on: August 29, 2022, 04:47:22 am »
1N4007 diodes and Hoffman sells them.
325 x 1.4 = 455 volts     I think with solid state rectification you may get more than 420v on node A on the B+ rail?  My guess is that it will be higher than 420v?
420/1.4 =  300 volts   If you only want 420v on node A, you may wish to use a PT that is closer to 300-0-300 instead of 325-0-325?
OR use a GZ34   325 x 1.3 = 423v
Offline rafaelctt
« Reply #30 on: August 29, 2022, 05:11:31 am »
Thank you!!
I have tried to use the same transformer as the one from Fender Pricenton. Do you know of a 300+300 (primary 240V) transformer model for a 5w amp with reverb?
I could maybe use a resistor between switch and B+A to drop those 20 volts.
20/100mA: 200 Ohm approximately. Would it work?
https://www.tube-town.net/ttstore/hammond-372bx.html
« Last Edit: August 29, 2022, 05:24:14 am by rafaelctt »
Offline rafaelctt
« Reply #31 on: August 29, 2022, 12:36:27 pm »
Do you think this transformer would be better?
« Reply #32 on: August 29, 2022, 05:11:03 pm »
« Last Edit: August 29, 2022, 05:24:37 pm by DummyLoad »
« Reply #33 on: August 30, 2022, 12:41:38 am »
Just to add a bit more confusion - with options
Offline rafaelctt
« Reply #34 on: August 30, 2022, 06:16:12 am »
Thanks. I intend to do an "All in one".
A small amp (300x300x200mm) in which it has 5w, reverb, distortion, tone control and an output switch for 5-3-1.5w. That's why I look for components that take up little space.
Offline rafaelctt
« Reply #35 on: September 01, 2022, 01:50:27 pm »
The distortion (as an effect) in these amps with gain and master control (in the first stage and before the final stage)?
Offline rafaelctt
« Reply #36 on: October 04, 2022, 04:24:26 am »
Once my first tube amp is done, we'll start on the second.
I have added two modifications (middle tone and master volume) do you think they can really be used to optimize this amp?
« Last Edit: October 04, 2022, 04:27:36 am by rafaelctt »
« Reply #37 on: October 04, 2022, 11:04:26 am »
imho the master volume on a 5W amp is redundant
you have a volume on the guitar, you have a gain knob on the amp, one more pot will not be impressive.
most guitarist that played through my 5W'rs set the gain, then use the guitar to roll up and down the loud
« Reply #38 on: October 04, 2022, 12:14:13 pm »
That Vox attnuator circuit should make a MV pot useless.
Offline rafaelctt
« Reply #39 on: October 04, 2022, 01:00:55 pm »
I TOTALLY AGREE WITH YOU. My idea is not to reduce power.
What I want is to be able to give very little gain in the Master and a lot in the Gain with the idea of ​​creating a distortion.
40 years ago I did it on some solid state amp designs of mine and it worked.
But in valves it is the second montage that I do and I wanted to experiment.
Can distortion be achieved this way?
« Reply #40 on: October 04, 2022, 03:10:49 pm »
The 0.002uFd and 200k pot at the 6V6 grid cuts below 380Hz. 13dB down on your low note. That sounds pretty gut-less, no?
There's three gain stages and two loss networks. As I figure it, there's just-barely enough gain to distort the 3rd stage with small plucks. No gross distortion.
Offline rafaelctt
« Reply #41 on: October 04, 2022, 04:02:22 pm »
Well, that's the problem. What would be the proposed solution?
« Reply #42 on: October 04, 2022, 06:04:04 pm »
build the TS into the circuit, but don't wire it in, instead use a coupler cap to the gain pot top and the wiper feeds the next stage.  Your guitar will be the TS for testing.
the magic number I use in a self-biased amp is the Vk (cathode vdc).  I want my drive AC signal >Vk, maybe up to twice.  Then I'll tame it as required.
Offline rafaelctt
« Reply #43 on: October 05, 2022, 12:57:03 am »
Thank you!!
I understand that I should lower the Vk below the guitar signal to have distortion?
Would I have to lower the value of the Rk (1k5)?
Do you have a schematic please?
« Reply #44 on: October 05, 2022, 03:45:51 am »
Vk is your BIAS, set it for proper tube power with NO signal.
It's simply to compare your drive signal to
You raise the AC signal either with more gain or less drain on that signal.  the TS is a drain
Offline rafaelctt
« Reply #45 on: October 05, 2022, 11:57:32 am »
I'm thinking of introducing an optional circuit like this:
