September 18, 2026, 05:43:10 am
Hoffman Amps Forum image Author Topic: Stancor line adjuster ??  (Read 8799 times)
Offline rafe
  • I have tube amps
« on: September 08, 2022, 04:58:44 pm »
This is a hefty transformer with a 2 prong plug on one side and a two prong outlet on the top. It has an 8 position switch on top 45 v to 150 v It has a voltmeter built into the front 0-150 v 10 v increments with the 120 being red. What is its purpose? Isolation Transformer??? Quasi variac ??
Rafe
Re: Stancor line adjuster ??
« Reply #1 on: September 08, 2022, 05:46:50 pm »
Pictures, model number?
Sounds like a bench transformer with switched secondary outputs. Use your ohmmeter to see if the output is isolated from input.
Offline rafe
  • I have tube amps
« Reply #2 on: September 08, 2022, 08:23:21 pm »
I forgot to write down the model # and I'm unable to go back out to the shop because of rain .....lot's of rain inundated with rain ....Too much rain   :BangHead:  , I'll post them tomorrow hopefully with a photo ,,,,and I'll check continuity
Rafe
Offline rafe
  • I have tube amps
« Reply #3 on: September 08, 2022, 08:29:18 pm »
Rafe
« Reply #4 on: September 08, 2022, 09:30:42 pm »
I highlighted your transformer in the attached pdf...
Offline rafe
  • I have tube amps
« Reply #5 on: September 09, 2022, 01:12:03 am »
It's on the "Isolation Power" page, so my guess is that it could be used with a 117v source as an isolation trans. ? The output recepticle being  permanently connected to the 115 v tap has me questioning that ?? if there is no continuity when off on all settings it should be alright as an I. T. ?
Rafe
« Reply #6 on: September 09, 2022, 01:23:55 am »
It's an autotransformer so there will not be any isolation. Read the description just above section B.
Offline rafe
  • I have tube amps
« Reply #7 on: September 09, 2022, 02:11:15 am »
Thanks I had read that , it really did not give me much to go on to be honest. It looks great though I picked it and several VTVM's a signal generator, resistors and 1% resistors at the flea market at a low price. I do appreciate your help on this . I'll keep it around in case they cut back our voltage I'd be lost without a tube amp  :icon_biggrin:
Rafe
« Reply #8 on: September 09, 2022, 02:52:07 pm »
It's 6 pounds. As an isolation transformer that's about 40VA at most; but this is 150vA. So it is, as said, an auto-transformer, no isolation.
15V steps are remarkably huge.
65V and 145V inputs are pretty silly. If that 145V was coming out of your walls, 115V incandescent lamps would be BRIGHT and last about 2 days. OTOH, 65V won't toast bread or light an incandescent brighter than a birthday candle.
It is really hard to see what market Stancor had in mind.
If you reverse the genders, it could turn modern 125V down to 70V, brown sound.
« Reply #9 on: September 09, 2022, 03:43:06 pm »
maybe "stepped" electric fencing, 65vac on the perimeter, 145 for inside ring  :laugh:
