September 15, 2026, 10:14:21 pm
Hoffman Amps Forum image Author Topic: Preamp filtering stage  (Read 4388 times)
Offline joesatch
  • save me from myself.
« on: October 11, 2022, 10:57:52 am »
Is it beneficial (with plate voltage being equal) to have a B+5 vs a B+4 on the beginning stages of the preamp?
Re: Preamp filtering stage
« Reply #1 on: October 11, 2022, 12:03:09 pm »
AC ripple is already exceedingly small in any preamp filter node you've likely encountered.
Someone might choose to have additional filter stages in a preamp when they're concerned about interactions between stages sharing a supply node, or when very high gain is present.
In such cases, another resistor & cap is not about "filtering ripple" but rather about "killing audio that's leaking from one stage to another."  Said a different way, it's about isolating one stage from another.
Offline joesatch
« Reply #2 on: October 11, 2022, 01:22:53 pm »
would it be better to add the B+5 to the high gain channel or to the clean channel ?
« Reply #3 on: October 11, 2022, 02:52:57 pm »
Unless we're talking about a specific amp (with a schematic posted) I can't possibly say whether/where one should add a filter node.
It's like asking, "Should I add a 3rd axle to a vehicle?"
« Reply #4 on: October 11, 2022, 05:19:30 pm »
what he said^^
the "rule-of-thumb" i learn't somewhere, you don't want to feed more than 2 gain stages from the same PS point.
draw in your mind's eye, the resistors between each Tap, are now located directly below their current location, "breaking-up" ground instead of "breaking-up" +DC
As stated before, the current draw in a preamp is low, doesn't "strain" the DCv.  So your objective now, squash AC-coupling onto your signal path.
