September 15, 2026, 09:38:32 am
Hoffman Amps Forum image Author Topic: Hoffmann 5F6A bias range  (Read 5572 times)
Offline Arry
« on: October 12, 2022, 02:00:42 pm »
Hi everybody, on my Fender Bassman reissue I recently installed a Hoffman 5F6A board. I noticed that the bias range offered by the pot is a bit limited, and would like to have the option to set the bias to about 70% of the maximum plate dissipation (something I cannot reach now, even with the pot turned all the way up).
Which resistor should I change to allow for a hotter bias? Thanks!
Re: Hoffmann 5F6A bias range
« Reply #1 on: October 12, 2022, 02:06:07 pm »
It's the one with the "Bias Range" flag and arrow. Make it larger for hotter bias.
Offline Arry
« Reply #2 on: October 13, 2022, 05:35:42 am »
Thanks Sluckey. What value would you recommend I try?
Arrigo
« Reply #3 on: October 13, 2022, 06:24:22 am »
1.2K, 1.5K, 1.6K, 1.8K, 2.2K, whatever it takes. I would set the bias pot to midrange and then experiment to find which resistor gets closest to your desired 70% point. This will allow you to be able to adjust hotter or colder than 70%.
« Reply #4 on: October 13, 2022, 07:23:07 am »
The install instructions tell you exactly what to do
https://el34world.com/schematics.htm#Hoffman_5F6A_Bassman_
Offline JPK
« Reply #5 on: October 13, 2022, 09:25:34 am »
Doug you really have some nice instructions. Hoffman Board Install Instructions link from above posted link:
« Last Edit: October 13, 2022, 01:29:16 pm by JPK »
I love tubes
Offline Arry
« Reply #6 on: October 15, 2022, 03:34:03 am »
Excellent, I hadn't even thought of checking the instructions booklet : )
Thanks!
