September 14, 2026, 06:08:17 pm
Hoffman Amps Forum image Author Topic: My first 5e3 build  (Read 26191 times)
Offline Ledvedder
My first 5e3 build
« on: October 27, 2022, 09:58:18 am »
I'm going to be starting my first 5e3 build soon. I've built several amps before (Ceriatone, Modulus, Headfirst). Mostly Marshall and Matchless circuits. This will be my first Fender circuit.
I decided to go with the kit from Boothill Amps. It was just easier than sourcing all the parts separately, as Boothill's selection seemed good. I added the upgrade for F&T and Mallory caps. I went with Hammond transformers from Antique Electronics Supply, and a cab from Guitar Cabinets Direct.
Now I'm trying to decide if I want to order Rob Robinette's board for his "optimized" layout, or just stick with the basic layout.
Offline Ledvedder
Re: My first 5e3 build
« Reply #1 on: October 27, 2022, 07:54:40 pm »
I started some PT wiring tonight.
Offline Ledvedder
« Reply #2 on: October 27, 2022, 09:39:03 pm »
I added backup rectifier diodes. I used uf4007 since I had no 1n4007 on hand.
Offline JPK
« Reply #3 on: October 28, 2022, 06:59:36 am »
I may build one of these too. Do you have a schematic you can post? I didn't see any docs on their website when I looked.
I love tubes
Offline Ledvedder
« Reply #4 on: October 28, 2022, 07:01:56 am »
Boothill just provides a layout diagram, but it's basically like all the other layouts available.
Offline Ledvedder
« Reply #5 on: October 28, 2022, 08:27:33 am »
Some input jack and pot wiring this morning. Not sure if I need to insulate the 1M resistor legs.
Offline thetragichero
« Reply #6 on: October 28, 2022, 08:46:33 am »
why go the long way instead of the short way?
a tip: keep in mind you can place parts in three dimensions
Offline bmccowan
  • Better builder than player
« Reply #7 on: October 28, 2022, 08:55:02 am »
Yup - and you should be careful to avoid the possibility of something grounding out against a bare wire - leave some space. It looks like those jacks might ground when you plug in.
Mac
John Prine
Offline Ledvedder
« Reply #8 on: October 28, 2022, 08:56:36 am »
I was looking for some good example pics, but couldn't find any. All the layouts I've seen have them going the long way around.
« Reply #9 on: October 28, 2022, 09:12:48 am »
     https://el34world.com/Hoffman/files/CommonHookups.pdf
     http://sluckeyamps.com/64DR/13.jpg
Or, if you will put the 68K resistors on the board like the original 5E3...
     http://sluckeyamps.com/5e3/5e3.pdf
« Last Edit: October 28, 2022, 09:35:41 am by sluckey »
Offline Ledvedder
« Reply #10 on: October 28, 2022, 09:48:05 am »
1M resistors redone.
« Reply #11 on: October 28, 2022, 09:56:26 am »
The tip lug of the top jack needs to be connected to the switch lug of the bottom jack. Do this for both sets of Hi/Lo jacks.
Offline Ledvedder
« Reply #12 on: October 28, 2022, 10:18:40 am »
Yep, I'm gonna connect them when I add the grid stoppers.
Offline Ledvedder
« Reply #13 on: October 28, 2022, 10:19:56 am »
1.5K grud stoppers soldered to both power tube sockets.
« Reply #14 on: October 28, 2022, 10:42:19 am »
Those 1.5K grud stoppers only need to be 1/2 watt.
Offline acheld
« Reply #15 on: October 28, 2022, 10:59:21 am »
Just a heads up on your pot wiring.
If I'm not mistaken, with your pots oriented as they are on the front of your faceplate, when you mount them on the inside of your chassis, your lugs will be pointed to the floor of the chassis.
Not such a big deal with a 5E3, but a royal pain with more complex amps.
Offline Ledvedder
« Reply #16 on: October 28, 2022, 11:09:33 am »
That's what came with the kit.
Offline Ledvedder
« Reply #17 on: October 28, 2022, 11:23:15 am »
As far as grounding, what is everyone's preferred method? A ground buss, or wires under the board from point to point?
Also, is it preferred to have 2 separate ground points for preamp and power sections, or a single ground point for everything?
« Reply #18 on: October 28, 2022, 11:36:39 am »
That surprises me. Can you post the actual Boothill layout you are working from? Scan or take a pic with your phone if you only have a paper copy.
Offline Ledvedder
« Reply #19 on: October 28, 2022, 11:56:57 am »
Here it is.
« Reply #20 on: October 28, 2022, 12:08:46 pm »
That layout clearly shows 1.5K @ 1/2W between 6V6 pins 5 and 6. Just guessing, but I suspect those 1.5K @ 5W are extras to be used as screen resistors if you choose to do so.
Here's a bunch of pics for a Boothill kit build. Step 4 clearly shows 1/2W resistors on the 6V6 sockets.
     https://smithtinkertech.wordpress.com/fender-deluxe-5e3-build-part-1/
Offline Ledvedder
« Reply #21 on: October 28, 2022, 12:17:51 pm »
OK, I contacted Dave to clarify. There are only 4 1.5k resistors in the kit. These 2, and 2 smaller ones (1w?), that would be used on the board.
Offline Ledvedder
« Reply #22 on: October 28, 2022, 12:30:53 pm »
Another question. I want to add an impedance selector. Can I just use a 3 way on-on-on toggle switch, or would I need something like this? https://www.tubesandmore.com/products/switch-rotary-impedance-selector-hammond-1600a-series
Offline JPK
« Reply #23 on: October 28, 2022, 02:33:12 pm »
The second one is way too many connections, hard to solder.
I'd do the on on on, just 4 terminals. 4, 8, 16 and common. I don't have a link but the one on all my amps are like that. Probably cheaper too.
« Last Edit: October 28, 2022, 02:36:18 pm by JPK »
I love tubes
Offline Ledvedder
« Reply #24 on: October 28, 2022, 02:47:22 pm »
Dave confirmed the resistors I've used are correct.
Offline Ledvedder
« Reply #25 on: October 28, 2022, 02:51:53 pm »
So a switch like this will work? https://www.tubesandmore.com/products/switch-carling-mini-toggle-dpdt-3-position-solder-lugs-flatted
I'm planning to do it like the attached image, along with an NFB switch.
Offline JPK
« Reply #26 on: October 28, 2022, 03:07:08 pm »
I love tubes
« Reply #27 on: October 28, 2022, 03:37:42 pm »
I've never seen a toggle switch that can be used to select between three impedance taps. The switch in that Rob drawing is a three position slide switch.
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #28 on: October 28, 2022, 05:19:23 pm »
I often use this one
Jumper between pin 2 & 4
pin 6 is 16 ohm tap
Pin 1 is 8 ohm tap
pin 3 is 4 ohm tap
pin 5 to speaker
https://www.amazon.com/SALECOM-Position-Guitar-Toggle-Switches/dp/B01JDUB4A2/ref=sr_1_1_sspa?crid=30TFJC2SMUXZU&keywords=on%2Bon%2Bon%2Btoggle%2Bswitch&qid=1666995336&qu=eyJxc2MiOiIyLjMyIiwicXNhIjoiMS43MSIsInFzcCI6IjEuNjgifQ%3D%3D&sprefix=on%2Bon%2Bon%2Caps%2C185&sr=8-1-spons&smid=A2TCCY26NO8P0X&th=1
« Reply #29 on: October 28, 2022, 05:36:20 pm »
...Not sure if I need to insulate the 1M resistor legs.
Now sure why you go the long way around. Won't this work? (Maybe even better on the other side of the lugs?
Offline Ledvedder
« Reply #30 on: October 28, 2022, 05:42:15 pm »
I redid them. See my previous post.
Offline Ledvedder
« Reply #32 on: October 29, 2022, 08:25:31 am »
Does it matter which lug of the indicator light the wires go to?
« Reply #33 on: October 29, 2022, 09:32:17 am »
it's just a standard 6vac pilot light, right? ac power doesn't have polarity
Offline Ledvedder
« Reply #34 on: October 29, 2022, 09:41:13 am »
It is. I just wanted to make sure because someone on tdpri said it was wired wrong.
Offline Ledvedder
« Reply #35 on: October 29, 2022, 09:43:16 am »
And how about the fuse wiring? Does that matter?
Offline acheld
« Reply #36 on: October 29, 2022, 10:00:39 am »
Yes.   Mains hot (should be black) goes to the connector at the end of the fuse.
In other words, when the fuse blows and you open the fuse holder, the live end is at the back of the fuse, not right at your fingers.
Of course you unplug before changing fuses, but your daughter might not.
« Reply #37 on: October 29, 2022, 10:03:23 am »
Power cord black wire goes to the end of the fuseholder. Side lug connects to power switch. Other side of power switch goes to one PT primary lead. Other PT primary lead goes to the power cord white wire.
     http://sluckeyamps.com/misc/bandmaster.pdf
Offline Ledvedder
« Reply #38 on: October 29, 2022, 10:12:33 am »
Ok, I'll have to switch it around. I wired the power switch to the middle lug of the fuse holder. That needs to be moved to the side lug, correct?
Offline Ledvedder
« Reply #39 on: October 30, 2022, 11:13:08 am »
While I'm in the build process, I want to include the mods I'd like to add. I've added several mods to my other builds (switchable gain structure, NFB, depth, etc). I like having the tonal options. I'm definitely adding switchable NFB and the impedance selector. But I'm also considering the switchable bias mod. Has anyone done it? If so, what are your impressions?
Offline JPK
« Reply #40 on: October 30, 2022, 02:06:24 pm »
So I'm a week or so behind you on this project. Looking at buying one now. Where are you putting the impedance selector switch? I want to use the rotary one I posted earlier and was wondering if I could use the hole for that external speaker jack? It looks like things are pretty tight on this chassis. Also the spacing between the output jacks is probably too narrow to fit this in one of those holes. Maybe I'll use the switch you're using. Sort of like this from Rob Robinette's site (no feedback switch, had one of those on an 18 watt and it was always off).
« Last Edit: October 30, 2022, 02:42:40 pm by JPK »
I love tubes
Offline Ledvedder
« Reply #41 on: October 30, 2022, 03:39:40 pm »
I'm honestly not sure yet. Looks like Rob's picture shows it in the speaker jack location. But I'm planning on keeping both speaker jacks.
Offline JPK
« Reply #42 on: October 30, 2022, 05:01:03 pm »
Oh geez, I saw that pic but didn't notice that it shows exactly what I want to do. I'll have to go look at those pics again. Looks like it will work. Mine will be a head so I only need one jack.
I love tubes
Offline Ledvedder
« Reply #43 on: October 30, 2022, 05:36:33 pm »
Slowly getting the board populated.
Offline Ledvedder
« Reply #44 on: October 30, 2022, 07:12:08 pm »
I'm working out placement for the fixed bias side of the switchable bias. If anyone knows of smaller 50k pots that would work better, please let me know. I think I'm gonna put the switch where the standby switch usually goes. I considered putting the NFB switch there, but figured it wasn't the best idea to run signal from the v2 cathode, all the way over to the switch, then back to the PI. It's unfortunate, since I'd rather have the NFB switch on the panel, instead of inside the cabinet.
« Reply #45 on: October 30, 2022, 07:29:52 pm »
I put a Bourns 25 turn trim pot in my Harvard 5F10.
Offline Ledvedder
« Reply #46 on: October 30, 2022, 07:46:59 pm »
Ohhh, that's interesting! It has the usual 3 lugs needed?
Offline Ledvedder
« Reply #47 on: October 30, 2022, 07:48:34 pm »
Test fitting the board before I move on. It seems it'll fit with the input jacks spun the correct way. There's a good 1/2" clearance between the tabs and the turrets/ground bus.
Offline Ledvedder
« Reply #48 on: October 30, 2022, 08:03:14 pm »
Can a 25uF cap be used for the fixed bias circuit? I have those on hand, but no 50uF.
« Reply #49 on: October 30, 2022, 09:18:00 pm »
how about this for the fixed bias: https://www.tubesandmore.com/products/trimmer-piher-single-turn-side-adjust-vertical-pcb-mount
25uf should be fine if they're the appropriate voltage rating. i've seen 8uf in big amps, not a puny deluxe
