September 15, 2026, 03:41:34 am
Hoffman Amps Forum image Author Topic: what does this 470k do?  (Read 8074 times)
Offline 12AX7
« on: November 11, 2022, 05:24:23 pm »
In this badcat schematic theres a 470k across the gain pot which according to the math would basically just change the 250k pot  to around 160k. Can't be there for that reason, so Is there some other reason for it and if so what?
https://schematicheaven.net/newamps/badcat_hotcat_30.pdf
Offline thetragichero
Re: what does this 470k do?
« Reply #1 on: November 11, 2022, 05:57:10 pm »
that appears to be exactly what it's doing
Offline 12AX7
« Reply #2 on: November 11, 2022, 06:08:34 pm »
I know, but i find it odd. 250k as about as low as i have seen for a gain pot so i find it odd the would wanna lower it that much. And if there is a reason i'm curious what it is.
« Reply #3 on: November 11, 2022, 06:33:05 pm »
Pure speculation...
The amp was built without that resistor but it was a little too wild. So the builder experimented a bit and discovered that adding that resistor tamed the wildcat just enough to be acceptable.
« Reply #4 on: November 11, 2022, 06:45:30 pm »
Bearing in mind the 1n5F coupling cap, the 470k will roll off more low end.
Offline isaac_teller
« Reply #5 on: November 12, 2022, 04:10:28 am »
https://schematicheaven.net/bargainbin/valco_510-1b.pdf
 This is the lowest gain pot I've ever seen in a tube amp. 100K
Offline NewYorker
« Reply #6 on: November 12, 2022, 09:17:14 am »
I think having the 470K in parallel would change the effective taper of the Gain pot?
That said, that probably wasn't the designer's main intent.
Ed
« Reply #7 on: November 12, 2022, 09:36:11 am »
I think having the 470K in parallel would change the effective taper of the Gain pot? …
No, the resistor would need to be connected to the wiper for the taper to be affected.
Offline 12AX7
« Reply #8 on: November 12, 2022, 10:12:23 am »
My guess would be that he found that 250k allowed too much gain after fining the design that sounded best except for the excessive gain and decided to tame it a bit that way. Thats what I recently was fighting with but tried that and wasn't thrilled with the result. But my guess is he liked it but rather then incurring the extra cost of having 160k pots made he just did it this way.
Thats my speculation because from the replies it seems thats all it accomplishes. And if so, cost would be the only reason not to have custom pots made. Adding a 2 cent R is a lot cheaper and makes for a far easier repair scenario.
Offline 12AX7
« Reply #9 on: November 12, 2022, 10:17:49 am »
Why would he want to roll off more lows with a small coupling value? Just curious.
« Reply #10 on: November 12, 2022, 10:21:40 am »
I doubt that was even a consideration. You think too much...   :icon_biggrin:
Offline 12AX7
« Reply #11 on: November 12, 2022, 03:51:15 pm »
Tell me about it ! I'll fix that tonite with beer if only for the night.
« Reply #12 on: November 12, 2022, 06:26:14 pm »
I'm way ahead of you.   :occasion14:
Offline 12AX7
« Reply #13 on: November 12, 2022, 06:47:04 pm »
You're a better man than i.....either that or you're on the east coast.  :laugh:
Offline NewYorker
« Reply #14 on: November 12, 2022, 09:50:48 pm »
Oops.  I was thinking about another matter, i.e. how to modify the 5E3 to get to the DeArmond R15 / Martin 112 design, where the Volume pots are 350K, and 350K pots are not readily available.
But we don't have to go there right now.   :icon_biggrin:
« Reply #15 on: November 13, 2022, 06:57:27 pm »
... I was thinking about another matter, i.e. how to modify the 5E3 to get to the DeArmond R15 / Martin 112 design, where the Volume pots are 350K, and 350K pots are not readily available. ...
500kΩ is "close enough."
There's nothing particularly special about the DeArmond/Martin amp:  it is a tweed 5E3 Deluxe with some different pot-values.  It's not gonna be materially different from any other tweed 5E3 Deluxe.
