September 08, 2026, 04:43:03 pm
Hoffman Amps Forum image Author Topic: Wiring a gz34 rectifier tube with 5v center tapped transformer..  (Read 7942 times)
Offline toobzilla
« on: November 20, 2022, 09:47:19 am »
Hi all!
I'm trying to finish up a 5f6a clone & am learning that all center tapped windings are not our friend, lol.. wired conventionally, w c.t. to ground, blows fuse after gz34 starts to work. unhooking the ct from ground keeps the fuse from blowing but its got a buzz that it doesnt have when hooked up. My question is what do i do with the center tap? .. is there a different way to wire it?.. any help would be appreciated, particularly in layman's terms as i'm a rookie at this... thanks in advance!
        -Jon
Re: Wiring a gz34 rectifier tube with 5v center tapped transformer..
« Reply #1 on: November 20, 2022, 09:53:33 am »
DON'T CONNECT THE 5V CENTER TAP TO GROUND! Just tape the end of the wire and tuck it out of the way.
Offline toobzilla
« Reply #2 on: November 20, 2022, 09:56:31 am »
Ive done that but it seems to introduce hum audible thru speaker even in standby.. that didnt exist in the 10 seconds or so before getting angry, lol.
« Reply #3 on: November 20, 2022, 10:02:06 am »
... what do i do with the center tap? ...
I will guess you have wired the rectifier socket like the original layout, with 5v wires to Pin 8 and Pin 2, then an additional wire from Pin 8 to the Standby Switch.
Try removing the wire from Pin 8 to Standby.  Instead, connect your 5v CT to the spot on the Standby Switch.  This is a valid use of the 5v CT.
If you still have buzz or hum after this, the 5v winding & the rectifier likely are not the cause.
« Reply #4 on: November 20, 2022, 10:05:33 am »
That hum is due to some other problem, not due to disconnecting that center tap from ground. At this point you have probably damaged the GZ34 and possibly damaged the PT too. Hope not. Try another GZ34.
Offline toobzilla
« Reply #5 on: November 20, 2022, 10:06:38 am »
original layout, with 5v wires to Pin 8 and Pin 2, then an additional wire from Pin 8 to the Standby Switch.  You guessed correctly,lol
 I'll give that a shot...
Thanks a ton!... much appreciated!
Edit; Fixed quote. Willabe
« Last Edit: November 20, 2022, 11:59:42 am by Willabe »
« Reply #6 on: November 20, 2022, 12:44:13 pm »
A 5V rectifier tube winding has to be connected the B+, not the ground. If you connect it to the ground (via a center tap), the B+ will short to ground, causing the Mains fuse to blow (hopefully before the PT is damaged). But as sluckey says, it may be too late for that warning.
If a 5V winding comes with a CT, you can connect the CT to the B+ (instead of connecting Pin 8 to the B+).
Offline Chriscolt
« Reply #7 on: October 27, 2025, 09:38:26 pm »
So, to make sure I understand this correctly, I use the 5V Center tap instead of pin 8 as the B+ supply which then gets connected to the junction of the standby switch and the positive pole of the reservoir capacitor (negative pole to ground). In this case my reservoir capacitor is a 100uf/1.2KV non polarized Film cap.
« Reply #8 on: October 27, 2025, 10:42:20 pm »
So, to make sure I understand this correctly, I use the 5V Center tap instead of pin 8 as the B+ supply which then gets connected to the junction of the ...reservoir capacitor (negative pole to ground).
yep
Offline Merlin
« Reply #9 on: October 28, 2025, 04:12:34 am »
The center tap is only for directly heated rectifiers. The GZ34 is indirectly heated; the output should be taken from the cathode pin. Leave the CT disconnected or you will be putting extra stress on the heater by letting ripple current flow in it.
« Reply #10 on: October 28, 2025, 04:19:22 am »
Oops. Missed the bit about the GZ34
Edit: although noting that, I’m not entirely sure why reservoir cap charging current pulses would be that much of a problem for a 1.9A rectifier filament that is connected to the cathode anyway, especially if the rectifier’s maximum reservoir capacitance rating is not exceeded. Interested to hear more about this.
« Last Edit: October 29, 2025, 05:02:41 am by tubeswell »
