September 14, 2026, 04:28:37 am
Hoffman Amps Forum image Author Topic: Vox AC4 question. Need explanations.  (Read 6111 times)
Offline johngovan
« on: November 25, 2022, 08:18:00 am »
According to the schematic posted, I'm just confused what's the use of the 100nf  coupling cap and 1M grid leak (red circles) in the last triode stage after the voltage divider (yellow circle)?
Why not just connect the grid of the last triode stage after the voltage divider? (Yellow circle)
The first schematic is the original circuit and the second schematic is edited, i purposely removed the two components to show my thoughts on paper. Hopefully you can help me to clear my thoughts on why they put those two components.
Online pdf64
Re: Vox AC4 question. Need explanations.
« Reply #1 on: November 25, 2022, 10:12:05 am »
Yes, they seem kinda pointless.
I don’t like that the output valve grid leak path relies on a pot wiper though, I suggest to add a back up resistor.
Offline johngovan
« Reply #2 on: November 25, 2022, 11:04:22 am »
Thank you for sharing your thoughts. Would 2.2M backup resistor enough to do the job?
« Reply #3 on: November 25, 2022, 11:23:41 am »
What’s the green box? Op Amp?
« Reply #4 on: November 25, 2022, 03:42:48 pm »
If you turn MV way down, it is possible to overdrive V2b before the output. Using R-C coupling may grid-block but also may 'duck' with less ugly sound. It *may* be worth trying both ways, altho it may take a long time to find the pot settings where it makes a difference.
« Reply #5 on: November 25, 2022, 06:01:37 pm »
... what's the use of the 100nf  coupling cap ...
Why not just connect the grid of the last triode stage after the voltage divider? ...
AC4HW1 Schematic
The snipped-away Green Box is the Footswitch that can lift the tone stack for "Hot mode."
The capacitor (C15) is likely "just in case" some small amount of DC volts is present on the footswitch cabling, which would then alter the bias of V2, and be audible as a popping noise when switching the footswitch.
« Last Edit: November 26, 2022, 10:21:13 am by HotBluePlates »
Offline johngovan
« Reply #6 on: November 25, 2022, 11:25:13 pm »
It's the foot switch connection to bypass the tone stack.
Offline johngovan
« Reply #7 on: November 25, 2022, 11:27:00 pm »
Thanks PRR. I will try it both ways and decide from there.
Offline johngovan
« Reply #8 on: November 25, 2022, 11:30:39 pm »
I see. It makes more sense now. Thank you Hot Blues.
EDIT: fixed missing quote tag --- HBP
« Last Edit: November 26, 2022, 10:22:51 am by HotBluePlates »
« Last Edit: November 27, 2022, 04:01:10 pm by kagliostro »
