September 16, 2026, 12:05:26 am
Hoffman Amps Forum image Author Topic: Fender Bias Electrolytic Value  (Read 6898 times)
Offline bbmade
  • Tubes and Tone
« on: December 26, 2022, 12:54:38 pm »
I've been searching the forum for this answer but am wondering what opinions are on the electrolytic capacitor value on the bias board.  I see most people up the voltage and many use a 47uf/100V capacitor there.
I have a bunch of 100uf/100V electrolytics but no 47uf.  Is too much capacitance here an issue?  Just seems like more ability to smooth and not a tonal issue.
I have no idea why I don't have 47uf/100V considering I usually only work on Fender amps.
ALSO - the 470ohm resistor often gets replaced with a 2 watt metal oxide.  Any issue with using a 3 watt?
Any insights are appreciated (as always).
« Last Edit: December 26, 2022, 01:00:37 pm by bbmade »
Re: Fender Bias Electrolytic Value
« Reply #1 on: December 26, 2022, 01:07:17 pm »
That's all OK.
You don't want to go 1,000uFd because (depending on details) it could take too long for the bias to come-up on cold-start.
Resistor wattage is space and cost.
Offline Latole
« Reply #2 on: December 27, 2022, 03:59:05 am »
Don't go up to 100 mfd, less is better.
A too high value will make the bias voltage arrive more slowly on the tubes grid, while the capacitor is charging.
And that's not what the tubes want.
« Reply #3 on: December 28, 2022, 05:18:08 pm »
... the electrolytic capacitor value on the bias board.  ...
I have a bunch of 100uf/100V electrolytics but no 47uf.  ...
I put 100µF 100v in the 1966 Pro Reverb and 1967 Super Reverb I used to own.  They performed flawlessly, and I never used the Standby switch on either amp.
Offline rake
« Reply #4 on: December 28, 2022, 09:56:13 pm »
why not put 2 caps in series? If that's all you have.
Correct me if I am in error but wouldn't 2 100uf 100v caps in series
end up a 50uf 200v equivalent?
Solid state has no soul........
« Reply #5 on: December 28, 2022, 10:29:19 pm »
why not put 2 caps in series? ...
Typical Fender amp has 470-1000Ω between the bias tap & the bias filter cap.  For example, my old Pro Reverb had 470Ω and 25µF/50v but the bias voltage was over 50v.  So I really needed ~100v rating for safety and a 100µF ca was convenient.
Let's use worst-case 1kΩ and a 100µF cap.  1 Time Constant = R x C, where R is in Ohms and C is in Farads.
     100µF = 0.0001 Farads
     R x C = 1000Ω x 0.0001 Farads = 0.1 second
     The link explains a cap is substantially charged in 5 time constants:  0.1 Second x 5 = 0.5 second
Even at worst-case, my Pro Reverb's bias has built up in about half a second.  However, its indirectly-heated GZ34 rectifier will take another 10-11 seconds to heat up and start passing high voltage.
The above is why I wasn't concerned about switching to the 100µF 100v bias cap, and why I never used the Standby switch (both of which are perfectly safe).
