September 18, 2026, 06:21:19 pm
Hoffman Amps Forum image Author Topic: BADCAT CUB II REVERB - NEED SCHEMATIC  (Read 6589 times)
Offline Jonas
« on: January 25, 2023, 08:13:57 pm »
Hi - I have a Badcat Cub II with reverb in the shop and looking for a schematic. Any one know where I can get the schematic?
Re: BADCAT CUB II REVERB - NEED SCHEMATIC
« Reply #1 on: January 25, 2023, 08:17:28 pm »
Try over at Music Electronics Forum
Offline Latole
« Reply #2 on: January 26, 2023, 03:37:13 am »
 Is it same as Badcat Cub II R 15 ?
R for Reverb ?
Can't find one in 15 minutes search
Good luck
Tubeswell ; https://music-electronics-forum.com
https://el34world.com/Forum/index.php?topic=17727.0
Chassis like this one  ? https://reverb.com/item/4857794-bad-cat-cub-ii-custom-shop-2007-grey-white
« Last Edit: January 26, 2023, 03:48:09 am by Latole »
Offline Jonas
« Reply #3 on: January 26, 2023, 07:26:56 am »
I could not find one either, but yes this one has reverb.
It looks to be the legacy version shown
« Reply #4 on: January 26, 2023, 07:40:31 am »
It doesn't take a schematic to fix a hand wired tube amp. I'm not saying they aren't helpful, just not always necessary. They mostly do the same things based around very similar parameters.If you can give a solid complaint, all voltages for all tubes and plenty of hi-rez gut shots, you are surrounded by plenty of talented guys who have helped to fix plenty of amps from thousands of miles away.
Offline Latole
« Reply #5 on: January 26, 2023, 08:42:49 am »
Schematic is very useful and a must here as we can't see the amp.
But if it is not available, we should work without it .
