September 08, 2026, 12:10:44 pm
Hoffman Amps Forum image Poll
70 year old P12Q (concert series)speaker Jensen in GA-40
repair DIY
1 (100%)
recone DIY
0 (0%)
recone Professional
0 (0%)
replace
0 (0%)
Total Members Voted: 1
Voting closed: March 07, 2023, 12:28:29 pm
Hoffman Amps Forum image Author Topic: 1952 les paul speaker repair  (Read 16828 times)
Offline rafe
  • I have tube amps
« on: February 12, 2023, 04:00:06 pm »
So it begins; I hope this isnt a lesson in futility after patience.
Rafe
Offline rafe
  • I have tube amps
Re: 1952 les paul speaker repair
« Reply #1 on: February 12, 2023, 04:08:25 pm »
This first 1/4 held together and not reinforced yet. the white paper in previous post is not a tear it was creased. I am not sure what i am going to use for reinforcement on the surround.
Rafe
Offline rafe
  • I have tube amps
« Reply #2 on: February 13, 2023, 02:39:44 pm »
less than 1/4 to go in Stage one...........What would you use to cover the surround? rubber cement?
Rafe
« Reply #3 on: February 13, 2023, 03:39:40 pm »
« Last Edit: February 13, 2023, 03:42:19 pm by mresistor »
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #4 on: February 13, 2023, 04:31:14 pm »
I have used Aleenes Tacky Glue (craft store) for speaker repair. It is really great stuff.
Can dap the glue between the cracks and it will hold the two cracks together with a flexible bond
If there is missing cone material have used tea bag material wetted with diluted Tacky Glue.
Have used diluted tacky glue for surround. Have read the rubber cement is too thick and will change the character of the speaker.
Here are a few speaker repair cases
https://stillampd.com/aetna-19a66w-tombstone-radio
https://stillampd.com/motorola-car-radio
https://stillampd.com/harmony-h303
Here is the magic stuff
https://www.amazon.com/Aleenes-Purpose-Tacky-Glue-8-Ounce/dp/B00178KLEY/ref=asc_df_B00178KLEY/?tag=hyprod-20&linkCode=df0&hvadid=167145009796&hvpos=&hvnetw=g&hvrand=2197703042289936963&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031560&hvtargid=pla-105934648140&psc=1
« Last Edit: February 13, 2023, 04:35:44 pm by scstill »
Offline rafe
  • I have tube amps
« Reply #5 on: February 13, 2023, 04:57:01 pm »
 this is what happens when I post part of the URL   (above)
I found it on amazon the link didn't work but the info in it did Thanks. To order caps for the les paul
Rafe
Offline rafe
  • I have tube amps
« Reply #6 on: February 15, 2023, 12:30:30 pm »
Waiting on the Bus .....forPRO-GRADE BLACK RUBBERIZED SPEAKER GLUE
Rafe
Offline bmccowan
  • Better builder than player
« Reply #7 on: February 15, 2023, 01:55:03 pm »
I don't want to discourage you, because I want to see how this comes out.
But if it does no work well... I have a couple of reconed P12Qs and they sound great.
And I have a couple of Jensens that I want to try and recone myself. There are a couple of excellent videos on the process on YouTube. Clearly you have the patience to do it. Ted Weber sell reconing parts, and some others sell kits as you likely know.
I have used model fabric airplane dope and tissue paper to repair torn cones. But I understand that the old style dope is no longer available. My repair attempts on surrounds and voice coils need to be classified as just that: attempts. :icon_biggrin:
Mac
John Prine
Offline rafe
  • I have tube amps
« Reply #8 on: February 15, 2023, 02:51:31 pm »
I am hopeful but not convinced, its just the surround (the cone looks fine) but it is 70 years old and I didn't test the voice coil . I put up a poll up top of this post and I am curious to see the consensus FWIW
Rafe
Offline scstill
    • Still Amp'd
« Reply #9 on: February 15, 2023, 07:07:15 pm »
I would proceed with the steps in the order of your poll.
After each step, test the speaker sound.
If it sounds right, stop. otherwise proceed to next step.
I had one jensen professionally reconed in my silvertone 1484, excellent
Offline rafe
  • I have tube amps
« Reply #10 on: February 20, 2023, 02:18:00 pm »
My hopes are still high. 24hrs to dry and then test. looks very good at this point. I have not even put a battery to it, so no expectations but high hopes. :rolleyes:
Rafe
Offline NewYorker
-ish
« Reply #11 on: February 23, 2023, 09:47:39 pm »
Oh boy ...
There is another thread here about 15" speakers.  I commented about a similar vintage Jensen P15Q-ish speaker that I had re-coned.  It sounds great, but it's not very efficient and kind of quiet.  I wonder at this point if I should have had it re-magnetized.  Granted, the magnet is relatively small anyway, but I imagine it may have lost some of its strength since the 1950's.
Ed
Offline rafe
  • I have tube amps
« Reply #12 on: February 23, 2023, 11:12:12 pm »
"Oh boy"
Things that make you go hmmmmm and wonder. It's not looking good for the speaker but I have not given up yet. I've had the speakers for my GA5's reconed with good results 8" alnico's from 59 and 60 .
Rafe
« Reply #13 on: February 24, 2023, 04:50:03 pm »
oh was/were  :icon_biggrin:
I had a pair of JBL 2035HPL, 15" 400w
the was is currently serving time as a lake-dragger for metal, anchor, and sea anchor of drift fishin,
the were was working then it self destructed, it's currently in use as small metal object catcher in the electronics shop.
Offline NewYorker
« Reply #14 on: February 26, 2023, 09:17:19 pm »
"it's currently in use as small metal object catcher"
You could probably pick up a table saw with that thing.
Ed
« Reply #15 on: February 27, 2023, 03:12:38 am »
 :laugh:
it's hard enough just picking up the speaker.
don't know what it's caught, I just got a request for a large magnet, "sure, come on over..."  :icon_biggrin:
Offline rafe
  • I have tube amps
« Reply #16 on: March 11, 2023, 08:28:22 pm »
Looks like I may have succeeded with this speaker after all MWBR..... :worthy1:
Rafe
Offline rafe
  • I have tube amps
« Reply #17 on: March 21, 2023, 09:35:21 am »
Hi Hoe, Hi Hoes....To miller-sounds it goes........ :l2:
Rafe
Offline NewYorker
« Reply #18 on: March 22, 2023, 09:47:39 pm »
You may have succeeded, but now ... ?
If you are in fact going to Miller Sound, tell Bill I said hi.
Ed
Offline rafe
  • I have tube amps
« Reply #19 on: March 23, 2023, 12:48:42 am »
Ed, It was a short-lived success, I played it for about 10 minutes through a Kalamazoo model 2, sounded great, but it just made a slight encore and was gone. I talked to bill on the phone, He said that it's pretty much impossible to do the repair that I did and save the speaker just to much stacked against it! I am not going to actually go there ,just the speaker via UPS.
Rafe
Offline RadioComm
« Reply #20 on: March 27, 2023, 03:39:34 pm »
Bummer... Worth the try though. I would have done the same.
Offline rafe
  • I have tube amps
« Reply #21 on: March 28, 2023, 03:45:50 pm »
Yeah  Bummer but I'm glad I tried . I have a 1952 P12N in there now and it sounds great other than a weird decay sound in the lower register. Low e string, the buzz weakens and disappears around A sharp(Ebay purchase, claimed No Issues and not cheap).All this is with volume around 1/2 below that it's hardly noticeable. But will probably need a recone. Next venture is going to be the GA50-T It is missing the 8"PM and I haven't checked the 12"PM yet (both Alnico Jensen's...) I am going to try to find
 a 1950 8" but may use a different one until I do ......I still have to hook up the tremolo on the les paul but this amp is "Superlative in tone"
Rafe
Offline rafe
  • I have tube amps
« Reply #22 on: April 13, 2023, 08:53:40 pm »
Speaker (P12Q) 1952 is back all NOS parts and ready to go . I will install it tomorrow. Super psyched.
Rafe
Offline NewYorker
« Reply #23 on: April 13, 2023, 09:30:43 pm »
Oh boy, oh boy, oh boy!
Offline rafe
  • I have tube amps
« Reply #24 on: April 15, 2023, 07:08:31 pm »
You are not kidding Ed, Shout out to Bill in Lansdale,PA I'll be sendimg some more His way !
Rafe
