September 17, 2026, 04:10:42 am
Hoffman Amps Forum image Author Topic: Effects Loop Questions  (Read 6156 times)
Offline Rontone
  • Ixnay on the Ampscray
« on: February 20, 2023, 08:58:07 pm »
I'm fitting an FX Loop into an amp, following the Valve wizard site and book, I've added schematics below, one is an example patched in to a JCM800 type amp, this amp I have is practically the same driver into EL34 power, but the two channels are coming in from 220k mixing resistors
- First I was thinking of powering it from the power supply node that the driver is on, it has a dropper resistor from the HT [Rp in the schematic] what would be a good voltage for the tube to be on?
- If I do tag-strip nearby to link the tube to the jacks and pot, should all the grounds go back to the preamp grounding bus bar, or can I do local star grounding, on the tagboard stand-posts for example, same goes for the cathodes on the FX Loop tube can they just be locally grounded to the chassis?
- The input cap C1, I already have coupling caps on my channel outputs, then 220k resistors where they join to the driver, so I don't think I need that C1, or do I?  Also C7 output coupling cap, should that be roughly similar to previous stages, 0.022u - 0.047u?
-C2 are both cathode bypass caps, in the cathode follower cap, does it still have the same effect on bass and freq. response, can I fiddle with it? Also in a cathode follower are those caps a similar voltage safety range, or should they be raised?
- C5 small 100pf cap, as with grounding, can this be just on the socket, soldered directly from grid pin to chassis or tag ground?
Re: Effects Loop Questions
« Reply #1 on: February 21, 2023, 12:29:34 am »
Where did you get fxlooppcb2.jpg ? Surely not from Merlin?
« Reply #2 on: February 21, 2023, 01:27:13 am »
Offline Rontone
« Reply #3 on: February 21, 2023, 10:47:43 am »
Yeah, its on the site, so I was hoping that was OK to pinch, as I have seen others posting his pictures from the site,
I didn't have to pull a soldering iron out of a stone to get them
Offline RadioComm
« Reply #4 on: February 21, 2023, 02:01:58 pm »
Hope this helps... Build and installed an effects loop into my JCM800. Works great. Here is the link:
https://el34world.com/Forum/index.php?topic=28311.msg311807#msg311807
Good luck
Offline Rontone
« Reply #5 on: May 28, 2023, 09:56:27 am »
I got a bit more done on this and fitted some hardware to start wiring it up,
I need help with the input and output of the FX loop, should it have attenuators as done in the pictures, I'm just wondering what values to try?
I have annotated a picture below of the rear panel with the master volume control, I can take the output from the tube and couple it with a cap to the tag board, then a resistor to the next tag, then split to the master volume pot,
On the main board there are some spare turrets, I have a space to add a coupling cap from the channel mix resistors then any attenuator resistors there too
Offline Rontone
« Reply #6 on: May 28, 2023, 11:48:55 am »
I could do something like this
