September 18, 2026, 07:26:37 am
Hoffman Amps Forum image Author Topic: Reverb signal view on oscilloscope  (Read 9946 times)
Offline mopar39
« on: March 08, 2023, 11:06:31 am »
I'm a advanced beginner (oxymoron?) and was wondering what the oscilloscope trace should look like if I put a low volt sine wave through my tube amp.
Re: Reverb signal view on oscilloscope
« Reply #1 on: March 08, 2023, 11:19:24 am »
from my last build
« Reply #2 on: March 08, 2023, 11:22:01 am »
Good question. I wonder too.
A lot depends on how you trigger the scope and whether you're using a digital scope or an analog scope. For an analog scope if you trigger on the clean sinewave that you put into the amp, I would expect to see a clean sinewave that's in sync with the input signal. And I would also expect to see several out of sync sinewaves that appear to just be free running across the display.
A digital scope would probably just show several sinewaves.
Of course I'm just guessing. I've never looked at the reverb signal with a sinewave signal source. Why don't you try it and post a pic.
Offline mopar39
« Reply #3 on: March 08, 2023, 11:54:41 am »
I will in the next couple days.  Thank You!
« Reply #4 on: March 08, 2023, 12:21:41 pm »
nope, me either
now that i've done and posted results  :icon_biggrin:
« Reply #5 on: April 08, 2023, 09:24:20 am »
... I've never looked at the reverb signal with a sinewave signal source. ...
I've only ever looked at reverb on a phasemeter, which is a scope set up for X-Y display of the Left & Right channels of a mix buss.  With that, you see the reverb imparts a bunch of delays of various times, at somewhat lower level than the original sound (depending on your reverb settings, of course).
I don't think a steady sine is a great signal for observing anything about reverb, just as one held note on the guitar doesn't really let you hear the reverb effect.  A short impulse gives much more information, and might make the reverb trails easier to see on the scope.
