September 16, 2026, 10:29:54 pm
Hoffman Amps Forum image Author Topic: JTM45 bias  (Read 5245 times)
g-man
  • Guest
JTM45 bias
« on: March 10, 2023, 12:41:07 pm »
Deleted
« Last Edit: August 06, 2024, 03:32:10 pm by g-man »
Re: JTM45 bias
« Reply #1 on: March 10, 2023, 12:50:24 pm »
... one tube was redplating. ... I can bias right at 34 mA with the bias pot at minimum. ... Should I change the 10K pot to 50K?
If you want to cool off the tube, you need a more-negative bias voltage.  You can get there by making the 220kΩ resistor smaller, or the 82kΩ resistor bigger.
A 50kΩ pot would give you a little more wiggle room because it increases the total resistance of the Pot+82kΩ.  But lowering the value of the 220kΩ will be more impactful.
g-man
  • Guest
Re: JTM45 bias
« Reply #2 on: March 10, 2023, 01:32:25 pm »
Deleted
« Last Edit: August 06, 2024, 03:31:30 pm by g-man »
