September 16, 2026, 10:23:46 pm
Hoffman Amps Forum image Author Topic: Nail Polish for Lifted/Removed Trace?  (Read 4737 times)
Offline jeff
  • Need input
« on: March 17, 2023, 08:47:01 am »
I removed(purposely) a trace on a circuit board.
Should I paint the exposed board with nail polish?
Should I just leave it?
I'm thinking if I don't seal it, the board could absorb moisture and become conductive.
   But is nail polish ok to use?
Is there something I should use instead?
Thank you
Offline acheld
Re: Nail Polish for Lifted/Removed Trace?
« Reply #1 on: March 17, 2023, 10:32:00 am »
By far the most common material used in circuit boards is glass reinforced epoxy laminate.   I have not seen this material absorb water under "normal" working conditions.
So, I'd let it be . . .
« Reply #2 on: March 17, 2023, 06:49:07 pm »
Is the rest of the board painted? If not, then what is the difference?
I would never worry about the binders used with fiberglass. Paper-base "can" absorb moisture but millions of pocket radios got along without special treatment. They die of floods or damp sheds.
