September 17, 2026, 09:32:56 pm
Hoffman Amps Forum image Author Topic: Lowering B+  (Read 6990 times)
0 Members and 2 Guests are viewing this topic.
Offline phsyconoodler
Lowering B+
« on: April 04, 2023, 02:27:28 am »
One more question about lowering B+ .
I used a 25watt resistor between the PT center tap and ground. Its worked just fine when ive done it with no ill effects that ive noticed.
  Everyone says use zeners or a mosfet circuit.
   Im wondering why not use just a resistor and maybe a high voltage electrolytic in reverse?
Re: Lowering B+
« Reply #1 on: April 04, 2023, 06:30:56 am »
That's so old fashioned.   :icon_biggrin:
Re: Lowering B+
« Reply #2 on: April 04, 2023, 07:40:18 am »
   Im wondering why not use just a resistor ...
(Deep) Class AB vs (mild) Class AB vs Class A
Played LOUD vs Played Soft.
Volts (Reduction) = Current (Increase) x Resistance (in-Series)
Sag vs No-Sag
Fast vs Slow
Guys that play mostly vintage-style amps, or that play low-volume relative to the amp's total power capability, or that like compression can forget how "stiff" or "fast" amps sound.  They can forget that not everyone wants the the softer, rounded-over sound.  They can forget that it can work fine at low volume, then collapse (or greatly restrict power output) at higher volume.
Some folks will recommend voltage-reduction strategies whose output does not vary so much with changing current.  Might be a zener, might be a voltage bucking transformer, might be a transformer replacement.
Offline jeff
  • Need input
Re: Lowering B+
« Reply #3 on: April 12, 2023, 03:32:24 pm »
How many volts were you looking to reduce the B+ by?
What value(ohms) resistor did you wind up using?
Re: Lowering B+
« Reply #4 on: April 12, 2023, 06:32:13 pm »
....why not use just a resistor ...?
Is the current demand from idle to loud "constant" or varying?
If near constant, a resistor can work.
If it is a fix-bias deep-AB stage that rises from 17mA to 130mA (7189), then working B+ will vary all over the place, especially if you drop a lot.
Re: Lowering B+
« Reply #5 on: April 13, 2023, 08:39:03 am »
PRR - does this mean a cathode biased amp would be a better candidate?  I've seen the voltage dropping resistors on the hv leads to the rectifier drop B+, does the also have this effect? Note lowering B+ at the pt cventer tap also effects filament voltage in all amps and also bias voltage in fixed biased amps.
Re: Lowering B+
« Reply #6 on: April 13, 2023, 08:53:35 am »
Please explain???
Re: Lowering B+
« Reply #7 on: April 13, 2023, 11:59:05 am »
OOPs   sorry  not enough coffee yet this morning     of course it's not going to effect the filament winding    duh .
« Last Edit: April 13, 2023, 12:38:46 pm by mresistor »
Offline jeff
  • Need input
Re: Lowering B+
« Reply #8 on: April 13, 2023, 12:23:37 pm »
No one thinks you're a j---. I think you were quoted because that's the part he wanted explained, not to call you out, but to understand what you meant.
I've been away for a while but most people are here to help.
Sometimes it's better to say explain instead of "that's wrong!"(maybe you know something I don't know, maybe I know something you don't know, maybe simple mistake before you had your coffe)
I wouldn't worry about it.
Everyone makes mistakes and we're all here to catch each others mistakes, not point them out to make each other look bad.
Peace
Re: Lowering B+
« Reply #9 on: April 13, 2023, 12:40:57 pm »
Sorry Sluckey      apologizies..
Re: Lowering B+
« Reply #10 on: April 14, 2023, 12:52:13 am »
May be you where thinking what happens when you feed a whole amp via a Variac
If you do that filaments voltage will be affected for sure
p.s.: I know lot of things, the problem is my brain very often apply an unwanted mix and not only before coffee 😭
Offline RadioComm
Re: Lowering B+
« Reply #11 on: April 14, 2023, 04:15:32 pm »
I don't know about everyone else... But Man... I've had my share of brain farts. Truly don't kick yourself in the butt for that, you're better than that, we all know it.
