September 17, 2026, 11:54:00 pm
Hoffman Amps Forum image Author Topic: Ampeg ReverberRocket R-12-R  (Read 5983 times)
Offline W5FH
« on: April 09, 2023, 08:16:55 pm »
Might I ask some folks here about this interesting reverb circuit in the Ampeg ReverberRocket. Attached is the schematic. I have been researching ways to tap off and recombine the reverb signals, in lieu of the standard Fender method of doing it across a 3.3 meg resistor with bright cap. My last 2 builds incorporated the Astroverb preamp which used a common anode mixer to recombine wet reverb signal with dry signal.
    It appears to me in the ReverberRocket circuit the first triode of V2 is splitting the amplified dry signal -- the plate component goes to V3 first triode (reverb tank driver) and the cathode component goes through 22K resistor to cathode of second triode in V2. It appears this second triode of V2 is a mixer with the dry signal applied to cathode and the wet reverb signal (from V3 reverb tank recovery triode) applied to the grid.
    I ask this to get opinions on how this reverb circuit sounded in this amp. Am studying the different circuits and open to others suggestions. I am intrigued by the method used in the Astroverb however that is a fairly specialized amplifier made more for a nice crunch tone with limited clean headroom. Looking more at clean designs here.
Re: Ampeg ReverberRocket R-12-R
« Reply #1 on: April 09, 2023, 08:31:35 pm »
I can't say about the Rocket but my Magnatone M10A has a very similar reverb circuit. Sounds very nice, but not splashy like the typical Fender.
http://sluckeyamps.com/magnatone/Magnatone_M10A.pdf    (easier to follow on page 4)
« Reply #2 on: April 10, 2023, 07:41:50 am »
You got it!
I suppose it can be as strong as a Fender.  But lower settings sound more akin to a plate reverb (though not quite as nice as an actual plate).
Here's a 1962 R-12-R Reverberocket.  I don't recall where I set the reverb for the clip below, but it was probably a bit below halfway:
https://soundcloud.com/hotblueplates/next-time-ampeg-rr
Offline jeff
  • Need input
« Reply #3 on: April 10, 2023, 07:48:14 pm »
No reverb Xfmr?
What type of tank does it use?
« Reply #4 on: April 10, 2023, 08:13:27 pm »
Gibbs, similar or equilivant to Accutronics 4FBxxxx
Offline W5FH
« Reply #5 on: April 11, 2023, 09:07:33 am »
Many thanks for the replies and information, and thank you Hot Blue Plates for the sound clip!
