September 16, 2026, 08:04:10 pm
Hoffman Amps Forum image Author Topic: SVT Bias and balance setting  (Read 53203 times)
Offline pbman1953
Re: SVT Bias and balance setting
« Reply #100 on: May 06, 2023, 11:03:52 am »
K1 and common are 72 using the vr 1 bias control
k1 and k2 are now at 0, using the vr2 bias control, just at Ampeg wanted.
« Reply #101 on: May 06, 2023, 12:25:30 pm »
Quote from: PRR
Then, with power OFF, trim VR3 for 4Kohms +/-1Kohms. Done. Have a beer.
Probably the easiest way to do this is to pull V1. Now connect one meter probe to chassis and the other to pin 3 of the V1 socket. Adjust VR3 until your ohm meter reads 15K. Done. Have a beer.
Offline pbman1953
« Reply #102 on: May 06, 2023, 01:55:49 pm »
Quote from: PRR
I set it before I put the amp back together
Offline pbman1953
« Reply #103 on: May 09, 2023, 08:48:09 am »
Any tips to lubing the fan to get it to be quieter? It has the stock fan
« Reply #104 on: May 09, 2023, 05:17:33 pm »
Is it squealing? Or air-noise? Cleaning the dust-scum for smoother airflow may reduce fan noise.
BUT a properly played SVT should leave no room for comments about its fan.
Offline pbman1953
« Reply #105 on: May 09, 2023, 05:53:38 pm »
The fan exterior is clean. I'd a little lube and it should be fine.
Otherwise a new one is $35 from Fliptops. I'd guess a good desktop case fan would be good too
« Reply #106 on: May 09, 2023, 06:35:39 pm »
Is it 12VDC? Or 120VAC?
Low-price DC fans hide the bushing under the label, maybe a rubber plug under the label.
Good AC fans come all different ways.
__________________
https://music-electronics-forum.com/forum/amplification/guitar-amps/maintenance-troubleshooting-repair/50093-
Offline pbman1953
« Reply #107 on: May 12, 2023, 12:55:08 pm »
After watching some SVT videos, I want to replace the screen ,22ohm resistors. Viewing them again, they did look brownish and un-healthy looking. Before, one was bad and I should if replaced them all, now I'll go back and do it.
The question is , since the schematic says nothing, what value are the diodes they are connected with?
« Reply #108 on: May 12, 2023, 01:03:06 pm »
Many diodes have the numbers printed on the body of the diode.
Offline pbman1953
« Reply #109 on: May 12, 2023, 01:13:31 pm »
does 555- 2 with a sides "S" mean anything?
I have some IN4007-  r-SI, 1000v, 1A diodes
« Reply #110 on: May 12, 2023, 01:25:27 pm »
Part numbers are on the schematic. According to this B15S parts list those 530555 diodes are rated 1000Vpiv and 1 AMP. A common 1N4007 has those exact same parameters.
Offline pbman1953
« Reply #111 on: May 12, 2023, 01:27:26 pm »
edit... fixed quote... sluckey
« Last Edit: May 12, 2023, 01:38:55 pm by sluckey »
Offline pbman1953
« Reply #112 on: May 12, 2023, 02:11:00 pm »
Is 2 watt overkill for screen resistors? Is it OK to sub a 20 ohm instead of a 22?
« Last Edit: May 12, 2023, 02:19:02 pm by pbman1953 »
« Reply #113 on: May 12, 2023, 02:21:17 pm »
Quote from: pbman1953
I'm at the parts shop and they have 15 ohm 5watt not 10 ohm. Still use?
I don't see any 10Ω resistors on the schematic.
« Last Edit: May 12, 2023, 02:24:15 pm by sluckey »
Offline pbman1953
« Reply #114 on: May 12, 2023, 02:22:32 pm »
[/quote
Going from 5 to 10.
Offline pbman1953
« Reply #115 on: May 12, 2023, 02:24:14 pm »
They had the 22 in 1/2 watt
« Reply #116 on: May 12, 2023, 02:26:28 pm »
I suggest using the correct parts.
« Reply #117 on: May 12, 2023, 02:38:12 pm »
2W 22r is 0.3 Amps. Screens have no business sucking that hard long enough to toast a big resistor. Either it is just old brown/oxidized varnish, or something is wrong.
And that is 0.3A *reverse* (since the diode bypasses normal screen current).
I have my own opinion (somebody over-designed) but certainly the stock factory values should work smokelessly.
What is a "parts store"? Like NAPA to get a tie-rod for the Jeep? DigiKey will sell any likely resistor, no compromise.
Offline pbman1953
« Reply #118 on: May 12, 2023, 03:17:06 pm »
Cool, I'll go stock. The part store is You Do It Electronics and has been in business for over 40 years. They have a parts floor and a audio video floor.
They stock NTE resistors in a large range of values
« Reply #119 on: May 12, 2023, 04:21:13 pm »
Just not the values you need!    :l2:
Offline pbman1953
« Reply #120 on: May 12, 2023, 04:24:57 pm »
[/quot
Actually they checked reserve stock and I lucked out
« Reply #121 on: May 12, 2023, 04:50:57 pm »
You need some practice with the quote button!
Offline pbman1953
« Reply #122 on: May 14, 2023, 09:10:21 am »
Well, I finished  the  amp yesterday and it  was quiet and awesome. I turned it on today and there's no sound and loud hum.
What do I do first?
Offline pbman1953
« Reply #123 on: May 15, 2023, 02:54:09 pm »
I found the hum. The positive signal wire fell off the square pre-amp plug.
A video I watched said that they are tricky and sometimes some tech's remake them.
Offline Latole
« Reply #124 on: May 16, 2023, 03:08:42 am »
Look it is a great store ; https://www.youdoitelectronics.com
Offline Latole
« Reply #125 on: May 16, 2023, 03:09:46 am »
You do a great job on this amp , congrat !
Offline pbman1953
« Reply #126 on: May 16, 2023, 04:26:22 am »
Thanks, but I have to give much of the credit this forum.
Offline pbman1953
« Reply #127 on: May 16, 2023, 07:23:44 pm »
Tube question-
The v1 for this amp is a 12wd7.  After playing his a bit , and since the volume escalates very quickly, what lower gain tube can I use?
« Reply #128 on: May 16, 2023, 07:44:42 pm »
> 12wd7
12DW7?? Altho I don't see one in the schematics in this thread.
>   ....the volume escalates very quickly
Are you trying it in the garage? Don't! The SVT is scaled for a coliseum.
Because the volume pot is LINear it will get real loud by "4" on the dial, and be real twitchy, in a small space. When your 40,000 screaming fans arrive, you will want that leverage.
Offline pbman1953
« Reply #129 on: May 16, 2023, 07:58:39 pm »
> 12wd7
There should be schematic on the first page of this post. It's being used in a studio. I'm just wondering if I could get a longer swing of volume. If it's no, I'll live with it
« Reply #130 on: May 16, 2023, 08:10:15 pm »
Never heard of that. Schematic shows 12AX7.
Offline pbman1953
« Reply #131 on: May 16, 2023, 08:21:59 pm »
Here you go. This is my pre-amp but not my power amp. There were versions with all 12ax7's, this one is with 12dw7's
The back plate on my amp shows V9-SVT
« Last Edit: May 17, 2023, 05:08:03 am by pbman1953 »
Offline pbman1953
« Reply #132 on: May 18, 2023, 07:11:37 am »
Schematic posted in #131
Offline TenderTendon
  • Living in the past
« Reply #133 on: May 18, 2023, 09:45:28 am »
That schematic is interesting. Not very common to see a 12DW7 in a guitar amplifier, but 4 of them? Am I interpreting this schematic correctly, that there is high voltage passing through the speaker plug connector?
You mess with the bull, you get the horns...
Offline pbman1953
« Reply #134 on: May 18, 2023, 02:53:36 pm »
Hi All,
The correct schematic is 3 posts back
« Reply #135 on: May 18, 2023, 03:01:14 pm »
Take a look at some Magnatone schematics to see more 12DW7s. Good idea on the speaker plug.
Offline pbman1953
« Reply #136 on: May 19, 2023, 05:01:30 am »
Picture from inside the case
Offline acheld
« Reply #137 on: May 19, 2023, 10:59:40 am »
In the pre-amp there's a 40uf@450V
If you mean C12b, then you could place an 80uF cap there w/o problems, as long as it fits.
Offline pbman1953
« Reply #138 on: May 19, 2023, 11:05:18 am »
I've already installed a 40/450. Is there an advantage with going with the 80? Plus it would fit
Offline acheld
« Reply #139 on: May 19, 2023, 09:00:02 pm »
Without going to the effort to do a real analysis, I seriously doubt there would be a noticeable (or any) advantage to a larger capacitor in that position.
