September 16, 2026, 04:15:39 am
Hoffman Amps Forum image Author Topic: 6P1P wiring  (Read 5478 times)
Offline Bieworm
  • I like it loud!
6P1P wiring
« on: May 09, 2023, 11:03:08 am »
Hi guys
Quick question: on the tube chart of a SED =C= 6P1P-EV the anodes (pin 1 and 6) appear internally connected. I presume only one pin needs to be wired to the anode resistor? Or am I totally wrong and do I have to jumper both pins? Same for the cathodes (pin 3 and 8)  and the control grids (pin 2 and 9)
Thanks for your input. I think one per pair is fine, but just to be sure😎
Re: 6P1P wiring
« Reply #1 on: May 09, 2023, 11:24:09 am »
Your ohm meter is your friend!
Re: 6P1P wiring
« Reply #2 on: May 09, 2023, 03:00:58 pm »
If there are 2 different pin that connects to the same internal component I'll connect only one
« Last Edit: May 09, 2023, 10:54:00 pm by kagliostro »
Re: 6P1P wiring
« Reply #3 on: May 09, 2023, 03:12:25 pm »
... the control grids (pin 2 and 9) ...
Looks like Pins 2 & 9 are "G2" (the screen grid).
The control grid is the one pin all by itself at Pin 7.
