September 23, 2026, 08:14:34 am
Hoffman Amps Forum image Author Topic: parallel'd ceramic caps  (Read 6463 times)
Offline joesatch
  • save me from myself.
« on: June 12, 2023, 09:09:29 pm »
audio circuit. lets say hypothetically i needed a 390pf ceramic cap and i only had a 330p and a 60p ceramic cap . can i parallel these without issue?
Offline acheld
Re: parallel'd ceramic caps
« Reply #1 on: June 12, 2023, 09:58:12 pm »
Sure, why not, as long as your max voltage is less than the smaller rating of each of the two caps.
You do know that I am an AI bot, right? :icon_biggrin:    And we like to hallucinate . . .
« Last Edit: June 12, 2023, 10:00:17 pm by acheld »
« Reply #2 on: June 12, 2023, 10:10:20 pm »
Quote from: Bing Sidebar AI
Yes, you can parallel two capacitors to get the desired capacitance. The total capacitance will be the sum of the individual capacitances. In your case, the total capacitance will be 330pF + 60pF = 390pF which is what you need. You can use these two capacitors without any issue. However, it’s important to note that when you parallel capacitors with different values, their effective series resistance (ESR) and effective series inductance (ESL) will also be different. This can affect the performance of your circuit
« Reply #3 on: June 13, 2023, 01:28:15 am »
Here we can chat with ChatGPT
Unfortunately asking if the signal at the output of a cathode follower is or is not inverted she/he replay near one time for yes and one time for not
I don't know if the accuracy of Bing Sidebar AI is better ....
« Reply #4 on: June 13, 2023, 07:07:17 am »
playing around with caps in the pico range can be problematic, like all caps, they are heat sensitive, pico's are extra sensitive, wants/needs heat sinks.
they also don't like long leads.  at audio frequencies it might not be a big deal.  with long legs and in ||, they make "stray" capacitance between the legs  :icon_biggrin:
Offline joesatch
« Reply #5 on: June 13, 2023, 08:02:45 am »
ok so y'all know that a 390pf is a klon cap. we'll see what happens
« Reply #6 on: June 14, 2023, 06:27:45 pm »
Well, it's not the Magical Diode, so everything should be just fine.
« Reply #7 on: June 14, 2023, 06:35:08 pm »
You guys should check out the "Gartner Hype Cycle."
I don't think we've hit the "Trough of Disillusionment" on AI yet.   :icon_biggrin:
« Reply #8 on: June 15, 2023, 07:23:25 am »
like all fake stuff before, Artificial sweeteners, artificial colors..... :icon_biggrin:
what's the coding saying "garbage in - garbage out"  the folly of man has no limits  :laugh:
Offline AmberB
« Reply #9 on: June 15, 2023, 11:58:13 pm »
Does anyone make 200PF caps?  2 of them in parallel would get you very close to the 390PF that you want and they would be balanced.  I suppose a 150PF and a 250PF would work also...
Offline joesatch
« Reply #10 on: June 16, 2023, 09:19:39 am »
i have a couple of out of spec ceramics that add up to exactly 390pf parrallel'd. going with those
Offline acheld
« Reply #11 on: June 16, 2023, 11:38:38 am »
Right now, there are 13 radial leaded 200pF caps in stock at Mouser.   I personally like Vishay and Kemet.
