September 20, 2026, 01:16:14 pm
Hoffman Amps Forum image Author Topic: BF Twin Reverb filter cap arrangement question  (Read 7349 times)
Offline markmalin
  • Malin Sweet Loraine
    • Malin Amplification
« on: August 27, 2023, 10:04:00 am »
Hi all
I'm working on what appears to be an early Blackface Twin Reverb.  I've pulled up the schematic for the AB763 and other BF fenders, but the filter caps on this one don't have the 2 reserve caps wired up in series.  They are in parallel, 2 20uf/524V caps.  I'm attaching a picture with the original caps.  I replaced these old caps with F&T's, 22uf/500v, in the same arrangement as they were in the picture.  I'm going to be transparent here and say that in adjusting the bias, as I let the amp run it started losing plate voltage on the power tubes.  I investigated and I see one of my parallel pair of 20/500v filter caps was reading plate voltage, the other was like 2.8V, so I figured I have a cold solder joint on the one.  But before I fix that I wanted to ask, does anyone have a schematic for a twin reverb that does NOT have the series pair of 70uf filter caps in the reserve filter section, but actually shows two 20uf's in parallel like on my amp?
humbly,
mark
"... there are Flying V's and then there are the ones shaped like peanuts..."  - my son at age 9
Offline Dave
Re: BF Twin Reverb filter cap arrangement question
« Reply #1 on: August 27, 2023, 10:32:50 am »
Ok, I'll chime in. So, as you know, two twenty's in parallel are not much different than two seventy's in series. I have not seen a "Twin" set up like yours, but I have seen plenty of instances where something seemed "out of place". The conclusion I have come to is that because of the sourcing of parts, or logistics issues, occasionally they had to make "on the fly" changes to keep production going.
Dave
Offline Latole
« Reply #2 on: August 27, 2023, 03:03:12 pm »
Look like a Vibrolux Reverb power supply witch use 16mfd
Offline markmalin
« Reply #3 on: August 27, 2023, 03:08:13 pm »
Interesting.  Yes, it's more like the Vibrolux schematic for sure.
« Reply #4 on: August 27, 2023, 04:09:58 pm »
Since twins have a ss rectifier then reservoir capacitance isn't critical and they capacitance could have been doubled or more without harm and some benefit.
I've not seen a BF Twin with that ps arrangement. However the Twin 6G8 had two 20uf in parallel as the reservoir capacitance.
https://el34world.com/charts/Schematics/files/Fender/Fender_twin_6g8_schem.pdf
Offline markmalin
« Reply #5 on: August 27, 2023, 04:35:20 pm »
I wonder if this is just a super early one
Offline Esquirefreak
« Reply #6 on: August 27, 2023, 04:44:00 pm »
I think that the early (AA763) Twin Reverbs actually had the 2 reservoir caps in parallel. Can't remember where I read it, but I was reading up on some stuff a couple of years ago.
The cathode resistor on the "roach side" of the tremolo tube - is it 56k or 100k? The early ones had a 56k.
/Max
« Reply #7 on: August 27, 2023, 06:50:27 pm »
The caps in your photo appear to have a 1963 date code:  "6339" below "Made in U.S.A." indicate 39th week of 1963.
The 6G8-A Twin also has all-parallel filter caps, with none in-series.  I would think very early Twin Reverb ams might have a power supply configured like the late blonde-era Twins.
« Last Edit: August 27, 2023, 08:09:08 pm by HotBluePlates »
Offline tdvt
« Reply #8 on: August 27, 2023, 07:00:36 pm »
The caps in your photo appear to have a 1963 date code:  "6339" below "MAde in U.S.A." indicate 39th week of 1963.
Pretty crazy that those are still in there 60 years later... but amazing too
« Reply #9 on: August 27, 2023, 08:13:25 pm »
I took some filter caps out of a 1964 AC30.  They must need replacing after 60 years, right?
However, checking the caps with a Sencore LC75 with 400v applied to the cap revealed leakage current lower than some modern aluminum electrolytic caps.
Offline markmalin
« Reply #10 on: August 27, 2023, 08:48:17 pm »
These guys were pretty bulged on one side.  They all had like a pea sized "wart" protruding, so I swapped them.  The rest of the amp is super clean for its age.  I swear...to me the Fender Twin Reverb is THE Fender tone.  I hate to send this one back once I'm done with it!
Mark
Offline Latole
« Reply #11 on: August 28, 2023, 03:45:44 am »
I often see that on many amps I fix.
