September 18, 2026, 07:49:49 am
Hoffman Amps Forum image Author Topic: terminal strip concerns  (Read 8972 times)
Offline joesatch
  • save me from myself.
« on: August 29, 2023, 01:58:17 pm »
i plan to use these strips instead of a board on a preamp build. I know folks use these all the time but the clearance between the terminal and chassis is a only a few mm. Any chance or arcing? What do folks do use spacers on these things?
Re: terminal strip concerns
« Reply #1 on: August 29, 2023, 02:03:47 pm »
Mount directly to the chassis.
Offline labb
« Reply #2 on: August 29, 2023, 02:23:00 pm »
Use them all the time. No problems. Don’t forget that the one in the picture the end terminals are grounded
Offline Soulfetish
« Reply #3 on: August 29, 2023, 02:54:23 pm »
I recently bought a handful of these from CEDist, and like like them a lot.
https://www.cedist.com/products/turret-strip-9-lugs-single-row-u-style
You have more flexibility, and they make more efficient use of space. I find that the grounded lugs on the style above is a hindrance. If I use them at all, I end up Isolating them from the chassis so I can control my grounding layout.
« Reply #4 on: August 29, 2023, 03:12:12 pm »
This is my preference...
« Reply #5 on: August 29, 2023, 03:41:10 pm »
This is the standard for our friend Darryl
« Reply #6 on: August 29, 2023, 04:56:27 pm »
Nice work!
the terminal blocks however... can't zoom well enough but if they have "sharp" corners, kinda like a "home-plate" shape, they will cut into wire.  the others posted before are rounded tops, no sharp corners.  I pitched all the plate shaped ones years back
Offline fossilshark
  • No life til' leather
« Reply #7 on: August 30, 2023, 01:08:15 pm »
I use the same ones Sluckey posted and I mount them right to the chassis. No issues with my last 2 builds in 1U rackmount chassis.
~SNOWBLIND~
Offline astronomicum
« Reply #8 on: August 30, 2023, 02:15:05 pm »
This may help answer your question.
https://en.wikipedia.org/wiki/Paschen's_law
« Reply #9 on: August 30, 2023, 05:22:48 pm »
...then here;
https://www.unitconverters.net/pressure/torr-to-psi.htm
back to re-reading, the 1st pass seemed like Charlie browns teacher
« Reply #10 on: August 30, 2023, 05:34:54 pm »
by successive deductions found that 730Torr is ~~14psi
added artwork
Offline joesatch
« Reply #11 on: August 31, 2023, 12:30:09 pm »
aint risking it. clearance from the plate terminal to the chassis is less than 1/32". gonna use spacers to lift it higher. terminal strip crisis averted
Offline dude
« Reply #12 on: August 31, 2023, 03:58:42 pm »
Where are these terminals sold, thanks
« Reply #13 on: August 31, 2023, 04:53:39 pm »
« Reply #14 on: August 31, 2023, 05:28:24 pm »
I've added nice finished pieces of wood like cherry for functional artistic. round edges, ~~20% over Tstrip footprint.
looking at the chart, appears you need 50 to 80Kv at 14psi to jump an arc;
 what I don't see n keep missing(?) is distance on the chart, going back for a 3rd read/look  :think1:
EDIT, FOUND: This is 327 V in air at standard atmospheric pressure at a distance of 7.5 μm.
cal'n later
« Last Edit: August 31, 2023, 05:31:34 pm by shooter »
Offline AmberB
« Reply #15 on: September 04, 2023, 03:01:02 pm »
I use those terminal strips all the time for my builds.  If I don't want to use the end lugs for grounding, which is most of the time, I cut off those terminals right above the terminal board.  That gets them out of the way, and you won't accidentally try to use one for parts mounting.
Offline Loomer
« Reply #16 on: September 06, 2023, 07:22:57 am »
I hope the OP won't mind me butting in on this thread, but feel it's quite closely related and might be an interesting extra bit of terminal strip information for people chancing on this thread later on, too.
Would the strips of the type in the original post be suitable for use as the star ground? Wondering this as they could be quite handy for SS bridge rectifiers - most layouts are made around valve rectifier setups and I've been looking at options for a neat way to integrate a FWB in my upcoming build and these could do the job... 🤔
