July 30, 2026, 06:34:49 am
Hoffman Amps Forum image Author Topic: Flip and Reverse visio image  (Read 6321 times)
« on: September 09, 2023, 09:16:25 am »
Hi guys.   I am going to gut a chinese made Vox AC15C1 and want to install a Hoffman Stout w/Reverb.  Problem is the layout is flipped and reverse from what is going to be needed.
The PT is on the right, the tubes are on the bottom and the pots are on the top, with the preamp to the left.
I have manually done this two times, once installing a Hoffman 5F6A into a Baldwin Organ Chassis, and once building a Hoffman Deluxe reverb into a head chassis. It's very painstaking.
Does anyone here have the talent/skills/tools to be able to flip and reverse the Hoffman Stout Reverb layout?
https://el34world.com/Hoffman/files/Hoffman_StoutReverb.pdf
Offline tdvt
Re: Flip and Reverse visio image
« Reply #1 on: September 09, 2023, 10:05:41 am »
I have needed to do this a few times depending on whether I was working from the top of the chassis (Fender tray-style) or from underneath the chassis (Ampeg/Marshall)
Hope this helps
« Reply #2 on: September 09, 2023, 02:05:08 pm »
> flip and reverse
Isn't that "rotate"? Print and turn? I suppose not.
Offline AlNewman
« Reply #3 on: September 09, 2023, 02:50:52 pm »
Oooh, that could be dangerous.  It looks like the pinouts on the tubes sockets and pots are on the wrong legs.  Might be more confusing than just using your noodle with the layout as a guideline.
« Reply #4 on: September 09, 2023, 03:40:59 pm »
Thanks you guys.. much appreciated..   I will probably resort to using the noodle.  It surely takes time and patience..    :icon_biggrin:
« Reply #5 on: September 10, 2023, 04:18:34 am »
Looks but aren't
Building pay attention to the PIN Numbers and all will go as expected
If pin numbers aren't present a pencil is your best friend
Offline dwinstonwood
« Reply #6 on: September 10, 2023, 05:19:16 am »
I can cut/paste the image in Photoshop so the text and pins aren't flipped. I'll upload a version in a while.
Offline tdvt
« Reply #7 on: September 10, 2023, 07:21:30 am »
Yeah, it definitely could be misread.
I used the flipped versions exclusively for making a reverse board, not for wiring.
« Reply #8 on: September 10, 2023, 07:50:32 am »
Is this what you wanted?
« Reply #9 on: September 10, 2023, 12:31:14 pm »
Actually   no it isn't   the power supply end of board needs to be to the right.. the tube sockets  need to be reversed. The pots are in the correct order the sockets are not.
The input jack needs to be on the left.
When I say "flipped" I mean in the vertical axis   not horizontally.  That way the ps end is on the right,  the pots and tube sockets are reversed vertically.
I was actually wrong saying reversed in my OP. Flipped on the vertical axis would be great.
« Last Edit: September 10, 2023, 12:46:41 pm by mresistor »
« Reply #10 on: September 10, 2023, 02:25:46 pm »
The problem is that if I flip each socket (while keeping them in the same order) then the wiring to the board will get crisscrossed. Hoffman laid out the components to line up with the socket pins. Notice that his wires do not cross except for pins 1 and 8 of V4. And, that could be eliminated by connecting pin 3 to the board instead of pin 8.
To be honest, I think it might just be easier for you to draw up a new layout and arrange the components on the board to line up with the socket pins.
« Reply #11 on: September 10, 2023, 03:06:08 pm »
 ah yes    I see  I will look at flpping the sockets  and the wiring to them     as well the pots have to be done too.. lest they turn backwards
heck might be easier to flip the chassis   or get another chassis made to fit the cab..
« Last Edit: September 10, 2023, 03:09:47 pm by mresistor »
